REVO STAGE 1 = NEW CLUTCH?
nealjohns Nov 16, 2010
  1. nealjohns
    nealjohns Member
    40
    really want a stage 1 revo for my s3 but dont want to fork out for a new clutch and possibly flywheel..
    so my question is this...
    will the clutch definately need replacing or does it depend how i drive it etc..
    ie could i get away with the stock clutch
    i had a stage 1 im my old leon cupra r and everything was fine(except it couldnt handle the power with stock parts)
  2. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    I managed about 15K on stock clutch with REVO stage 1.
    Car hasnt had a hard life neither.
    Just had a new one fitted by AUDI on the very last day of warranty (long story/ pure fluke).
    Apparently, OEM clutches fitted to later cars and warranty replacements are stronger units as there are a number of reported standard S3s with failed clutches.
    Not a VAG strong point.
    AUDI deny this of course, forums suggest otherwise.
    That said, some are running Stage 2+ on OEM set up without any real problems.
    No definative answer really.
    Personally I wouldnt let it stop you, its a lottery, and a stage 1 map makes such a huge diffenece its worth the gamble.
    Good luck.
    Paul
  3. thebott
    thebott Member
    211
    im running an s3 with mtm stage 2 upgrade around 330 bhp and still on oem clutch no problems .
    go for a map car is begging for it
  4. S3Alex
    10,800
    4,803
    Not neccessarily...some cars and some clutches will do Ok with Stg 2,and some wont.
    Mine was Ok on Stg1,and as soon as the torque went up,that was the end of the OEM clutch.
    My advice would be to set some cash aside,just in case it gives in,and also to remember that if the clutch goes,the DMF will need replacing as well.
  5. robern2
    robern2 Member
    60
    DMF doesn't necessarily need replacing as part of a clutch upgrade - my ed30 is a little over 360bhp and the DMF was perfectly fine when I upgraded to a Helix clutch.
  6. Y444GAR
    Y444GAR Member
    198
    My S3 has done 12k miles on the standard clutch and has been stage 2+ for around 10K miles. No clutch slip yet and the car is driven quite hard.
  7. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Same here.
    If you replace in early enough the DMF will be ok.
  8. DeckedS3
    DeckedS3 Well-Known Member
    871
    299
    I had no issues with stage 1, it was stage 2+ that killed it!
  9. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    Stage 2 not driven overly hard - 24k on current clutch - been on Revo for 4k miles.
    No dramas.
    Best £499 I ever spent!!
    DO IT.
  10. Ads
    Ads License to drive
    8,230
    608
    So taking into consideration the 'potential' risks of melting your clutch, I guess a revo stage 1 is not a wise move/risk for DSG equipped cars?
  11. akash_sky1
    akash_sky1 Active Member
    1,181
    DSG box can handle 380/90 lb ft no problem
  12. Ads
    8,230
    608
    What's your source?
    What can a manual clutch handle?
  13. akash_sky1
    1,181
    Just from seeing what many others with DSG are pushing out with no reported problems after several thousand miles, from spending far too much on VAG tuning forums. Some companies are offering uprated DSG clutch packs that can handle over 400 lbft safely now.
    Standard clutch is a bit of a lottery, if its a fresh one and not one of ones seemingly made of chocolate then seems to be about 340 ish but only for a few thousand miles before they give up the ghost, and also depends on your driving style. DSG seems to be a safer bet TBH for tuning on if you dont want to replace the clutch on stage 2+.
  14. Brett Butler
    Brett Butler Member
    664
    13
    How long any clutch lasts whether it be stock, stage 1 etc. really is all down to how it is driven, and how often you are pulling away as fast as you can every time, or going for it in 2nd,3rd, clearly the higher the stage the shorter the time the parts will last again with how you drive it.
    I think Stage 1 should be fine if you are not flooring it every set of lights and roundabout etc.
  15. NICK-C
    NICK-C Nick
    711
    114
    43
    Interesting read guys, I am hoping to go stage 1 soon so hope the standard clutch will be OK.
  16. nealjohns
    nealjohns Member
    40
    cheers for the input guys...
    think thats put my mind at rest..
    like you say,paul,its a bit of a gamble on whether it will hold but you think the stage 1 is clearly worth it..
    bugger now i got to find 500 quid :-/
    mrs wont be impressed.it'll be coming out of her xmas present fund...
  17. Brett Butler
    Brett Butler Member
    664
    13
    Yes Stage one is by far the best value, and worth every penny
  18. nealjohns
    nealjohns Member
    40
    yeh sounds like its worth the money..
    altho just seen the other new thread about the clutch judder and that its connected to the dmf possibly. im sure mine does that a tiny bit.always thought it was normal tho..
