Revo Software Settings ???
NOLAN NAIDOO Aug 18, 2007
  1. NOLAN NAIDOO
    NOLAN NAIDOO Untidy S3
    Hi Guys,
    Anybody with Revo Stage 2 map, if so what timming and boost settings are you using?? Iv'e been adjusting with the tunner, but im needing advice for most power and safety to engine/turbo. It is numbered 1 to 10, the settings.
    2003 S3, Revo stage 2,63mm decat exhaust,Forge Tip, using 95 unleaded in South Africa.
    HELP!!!:rockwoot: :rockwoot:
    NOLAN NAIDOO
    aka. Untidy S3
    Port Elizabeth
    South Africa
  2. ANDYTQ
    ANDYTQ Well-Known Member
    1,186
    106
    It all depends on the spec of the car,fuel etc,use vagcom to check out intake temps(block4),knock levels(timing retard)(block20)(adjust timing with sps3 until you get no more than 6 on any cylinder try to average 3 on middle 2 cyls ,thats the sweet spot).Only try high settings if you are running high octane fuel ,have suitable full exhaust and fmic.The colder it is the safer it is to run high settings.Start with lower settings and slowly build it up until you find the sweet spot,also see revo sps3 guide.Cheers Andy
