Revo couldn't map to stage 2+ due to low fuel pressure?
nickmck Feb 6, 2013
  1. nickmck
    nickmck New Member
    15
    Hi,
    Can someone please help, I have a a4 b7 2.0tfsi with an autotech hpfp, I took my car to Revo hq in Daventry,
    they mapped the car and took it out to log data and the fuel pressure was around 110 and they said it should be around 130,
    iv stripped the pump down to check the internals and i cant see any wear, there was a small circle imprinted on the cam follower
    could this be an issue? or does anyone have any suggestions on what the problem could be?
    Nick.
  2. Custardsucker
    Custardsucker Member
    112
    110 bar is fine for standard hpfp, Audi spec is and i quote 'approx 50 bar at idling speed and approx 110 bar in certain parts of operating range' at coolant temp of approx 85 deg C. Do you have a spec from autotech and if so what do they quote?
  3. nickmck
    nickmck New Member
    15
    Hi, so iv taken it out with a friend who ran a log and its now running 130 fuel rail pressure which i think is good? its the same as his s3 and he also has a autotech fuel pump. i will try get it mapped again tomorrow.
    thanks for your help.
  4. Steve220
    Steve220 Member
    234
    15
    130bar?! Is that a writing error or do you mean 130psi?
  5. nickmck
    nickmck New Member
    15
    it was 50 bar idle and 130 bar under acceleration, does that sound right or is there a problem?
    its not misfiring and it seems smooth.
    Thanks.
  6. Steve220
    Steve220 Member
    234
    15
  7. nickmck
    nickmck New Member
    15
    I find it hard to believe also! I'm a plumber and we work in bars but in single figures!
    I will go with the apr if this isn't working or i'll get one if it fails.
  8. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,254
    586
    110 bar is standard. If it is 130 bar it has a map on it. HPFP's can be very unreliable.
    Rick
