Reversing Sensors - Graphic Display?
mpc May 26, 2013
  1. mpc
    mpc Member
    118
    Hello,
    My friends Audi A5 does not have the graphic display like I have seen on some other Audi's - is this something that I could get on mine with a software update or something or is it a completely different system?
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    tell us the year of the car and as long as its factory fitted (ie MOST & canbus) then providing your module supports graphic display then it can be enabled with vcds.
  3. NHN
    29,300
    1,702
    Welcome to the forum.
    As denoted, all comes down to the systems fitted already, if it can be made to work, only one way to find out tbh & that's login with vcds & see if module 10 will allow this facility.
  4. mpc
    mpc Member
    118
    It's a 2009 A5 quattro with loads of extras and has the MMI system.
  5. NHN
    29,300
    1,702
    As advised, login with vcds to see what options you have.
  6. mpc
    mpc Member
    118
    Please excuse my ignorance but what exactly do you mean by "login with vcds"? Is that something I can do myself or do I need professional help?
  7. SL11CKK
    SL11CKK Active Member
    693
    35
    You need to buy VCDS diagnostic cable to allow you to do a bit of tinkering. You could buy one or find somebody who has the lead.
  8. mpc
    mpc Member
    118
    Ah ok, like the following?
    I'm presuming that the 11-11-3 is a newer version of the cable/software than the 10-6-4? Is this correct? What is the latest version available, what is a reasonable price to pay?
  9. NHN
    29,300
    1,702
    Those are fake, counterfeit illegal cables & are not allowed on the site, your post will be edited.
  10. mpc
    mpc Member
    118
    OK, so help me out here!! - i'm a newbie - please point me in the right direction....
  11. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Also the cheap copy cables allow you to see some fault codes etc not everything and they don't allow you to make changes to any settings. Correct ?
  12. a6_chris
    1,883
    160
    As you don't state your location we can't suggest a user.
  13. mpc
    mpc Member
    118
    Sorry, I'm north east England - Nr Middlesbrough
  14. a6_chris
    1,883
    160
    Send a PM to jb0o.
  15. NHN
    29,300
    1,702
    You can ask an owner of vcds to look for you or consider purchasing a genuine version of which I sell :)
  16. mpc
    mpc Member
    118
    How much are you selling them for? Do you also supply the software?
  17. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,110
    9,117
    Please pm NHN directly for prices. :) x
  18. sheebs
    sheebs New Member
    Hey i have a 2008 audi a5 with the audi symphony system, it has the full colour screen but doesnt show a display either any idea if it can be activated. dont know anyone with the cables and software and cant afford to buy them at the moment
  19. a6_chris
    1,883
    160
    I'm pretty sure Concert/Symph can't have them enabled, but I'm guessing theres no harm in trying with VCDS.
  20. FinnMc1
    FinnMc1 Member
    67
    What exactly am I looking for when trying to activate this with VCDS, just going to have a look now, is it in long coding?
  21. NHN
    29,300
    1,702
    Optical Illustrative tick boxes, normally the pdc module is enabled & maybe in your head unit.
  22. FinnMc1
    FinnMc1 Member
    67
    I found something with that name in the long coding but when I tried to enable it the standard codes entered by VCDS didn't enable the change. Any additional access codes I can try on that??
  23. NHN
    29,300
    1,702
    If it wouldn't accept or allow the coding change then its more than likely not possible with current setup.
  24. FinnMc1
    FinnMc1 Member
    67
    It let me check the box to select it and close the helper it just seemed that the access codes down the bottom when I tried to save it weren't accepted for some reason. Ill have another look in awhile, but ye likely its just not possible I guess, thanks
  25. NHN
    29,300
    1,702
    Its possible, just maybe not with your current setup.
