reversing beep and parking sensors
cal 7888 May 13, 2013
  1. cal 7888
    cal 7888 Member
    45
    The beep when I put the car in reverse is so annoying! Is there anyway to turn this off? Or disconnect something?
    Also my parking sensors don't always work! Any thoughts?
  2. percymon
    percymon Member
    156
    you can alter the volume and tone in the DIS menu, although i don't know whether the lowest volume setting is actually muted or so low it doesn't matter
  3. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    I've always wondered about the volume, but my car doesn't have the options in the dis
  4. Ash187
    7,496
    744
    can be done in VCDS if not on the DIS... older cars did not have this function on the DIS
  5. fangio
    fangio Well-Known Member
    1,507
    180
    :ermm: It's a self-check on the sensor circuit, so if you could't hear it you wouldn't know they weren't working!
  6. cal 7888
    cal 7888 Member
    45
    Ahhh I see! Ill have a look chaos! Will it be in the manual? And I think they've only ever worked once! Not sure why they don't work all the time! :/
