Reverse parking sensor switch.
benjie Jun 20, 2011
  1. benjie
    benjie Well-Known Member
    1,223
    305
    I wonder if someone can confirm the characteristics of this switch for me. When ignition is on, I assume the switch is off. When the car is put in reverse, does it automatically come on? Or do you have to manually turn it on if you need it when reversing? How about switching off, does it stay on until you switch it off?
    (and am I right in thinking it has a little orange indicator light in the switch?)
    Sorry for all the stupid questions, I'm just trying to clarify how it works.
  2. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    if im right, the power for the reverse unit comes from the reversing light bulb power supply.
  3. Cabbyfan
    Cabbyfan Active Member
    840
    34
    There is no switch for rear sensors, there is one for front sensors but very few cars have them. The rear ones work automatically when you select reverse gear.
  4. benjie
    1,223
    305
    Ah right, so the switch in the dash (next to the ESP switch) is for the front sensors? Are they a standard on/off operation, like the ESP switch with the exception being it has a little light?
  5. NHN
    29,521
    1,765
    Assume its oem then Cabby is correct, have you checked front bumper for sensors?
  6. benjie
    1,223
    305
    Sorry, I'm not being very clear. I don't have the sensors, I'm looking to use the switch for an aftermarket rain sensing wiper system. I want a permanent switch that will activate/deactivate it when I choose and I didn't fancy the awful switch that comes with the kit, was hoping to get something a little more oem & the PDC switch seemed a good choice.
  7. T0m
    T0m Active Member
    516
    26
    I have the switch with front and rear parking sensors, when reverse is selected both the front and rear sensors come on automatically however the switch can be used independantly and switches both the front and rear sensors on/off. They switch off automatically when you go above 10mph and you cannot turn them on again unless you are stationary or under the 10mph.
    p.s. the light on the switch is green!
  8. NHN
    29,521
    1,765
    Its a push to touch switch though isnt it, its not locked switch position right, like a light switch on/off.
  9. benjie
    1,223
    305
    Right I see, so assuming I hook it up to a 12v source that's on with ignition (and connect it to the rain sensor unit) then I can touch it to turn on (with green light) and touch to turn off. Am I right? (Luckily, my friend is good with auto electrics, as I'm not too clues up on it!)
    Us that right?
  10. T0m
    T0m Active Member
    516
    26
    NHN you are correct it is a push to touch switch its not a locked position switch...Im not sure what 12v source to hook it up to but in theory yes I suppose you are right it is nice that it engages automatically when you select reverse I couldnt be doing with thh hassle of remembering to switch them on! Saying that my front ones are playing up at the mo and driving me mad telling me something is there when it is not.
    Also with the original OEM system you get a beeping sound from the front of the car for thefront ones and one from the rear for the rear ones so you know which ones are working!
  11. benjie
    1,223
    305
    Ok cool, I think I'll try the 12v to get it constantly on as I want the switch to de/activate rain sensing wipers.
  12. NHN
    29,521
    1,765
    Huh, why not just fit oem system & enable/disable via stalk, strange way people do things.
  13. benjie
    1,223
    305
    There wasn't an oem system on the b6 (as far as I'm aware) and I don't want to go down the route of changing the windscreen etc. for the B7 oem wipers. I can do it far cheaper another way - not strictly oem, but also not very expensive.
  14. NHN
    29,521
    1,765
    I'm sure my B6 S4 had auto wipers, I had auto lights for sure.
  15. benjie
    1,223
    305
    I have auto lights too, but there's no mention in ETKA of a mirror with rain sensor and I've never read about anyone with it.
    ... Done a bit of reading and consensus is that it was unavailable on the B6, despite being available on earlier Passats, Boras & Golfs!
  16. quattrojames
    14,060
    583
    How sure mate? I'm pretty certain auto wipers never reached any B6 models.
