Reverse Lights not working Audi A3 1.8 T
andybubbles Nov 27, 2005
  1. andybubbles
    andybubbles New Member
    29
    Hi guys,
    My reverse lights are not working /ubbthreads/images/graemlins/frown.gif
    I changed the bulbs....and nothing. I changed the fuse on the drivers side....and nothing.
    Any ideas whats gone wrong or any suggestions? Its a pain without them and prety dangerous too, especially with tinted windows at the back.
    A
  2. HTC
    HTC Active Member
    3,428
    9
    Just fixed the reverse lights on me girlie's car yesterday.
    On of the wires to the reverse light switch on the gearbox had broken.
    It will either be that or perhaps a faulty switch itself. If its the switch they are cheap and easy to swap.
  3. andybubbles
    29
    Thanks /ubbthreads/images/graemlins/wink.gif
    I guess it was an audi a3 too?
    How exactly did you fix the wire? Is it pretty simple?
    Also when you say switch do you mean the fuse? because i changed that and it stil didnt work /ubbthreads/images/graemlins/frown.gif
  4. god_thats_quick
    2,507
    nope HTC means the actual switch on the side of the gearbox.
  5. nickel101
    nickel101 Member
    97
    i too have a dodgy reversing light on my 1.8T a3.
    there is a sensor in gearbox, and i beleive to replace it you have to drain off the oil and is very time consuming...
    it's not tested in the MOT so i not worrying about it yet..
  6. andybubbles
    29
    Cheers, Im taking it to the garage this week!
    il let you all know what the problem is incase it happens to anyone else /ubbthreads/images/graemlins/wink.gif
  7. HTC
    HTC Active Member
    3,428
    9
    If its an 02j gearbox then you don't have to drain anything. Its a 10 min job.
  8. nickel101
    nickel101 Member
    97
    mine car is a 99 A3
  9. andybubbles
    29
    Mines a 98 /ubbthreads/images/graemlins/wink.gif
  10. HTC
    HTC Active Member
    3,428
    9
    Which means they are probably both pre facelift cars.
    If you look down at the shift mech ontop of the box you should see a plastic blob. This is the reverse light switch.
    click me
    This is what later cars have. Its the bolt thing with the black connector on it next to the base of the shift weight.
    Click me as well
  11. andybubbles
    29
    nice one, you certainly know your stuff!
  12. chrisb
    chrisb Member
    141
    have a look here as well. The pic is of my TDi, but I think the 1.8T is similar, and there's a list of parts to make a neat repair.
  13. andybubbles
    29
    Cheers!
    Mechaninc has ordered the part so should be fixed soon /ubbthreads/images/graemlins/wink.gif
