Reverse light switch how to??
Gstar51 Mar 23, 2012
  1. Gstar51
    Gstar51 Member
    79
    Got my reverse light switch today, anyone got any how to guides for my A4 b6 6 speed manual? Or shall I just buy a Haynes manual ??
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,665
    9,654
    Have a look in here.
    AudiDIY.com Audi B5 A4 DIY Articles
    Sandra.
  3. Gstar51
    Gstar51 Member
    79
    Cheers for that Sandra, lots of useful info on there, but not what I'm looking for.
    Ill pick up a Haynes manual on the way home from work.
  4. Sandra
    26,665
    9,654
    I will move this thread into a4 section see if any boys can help out before you buy the manual. :)
  5. quattrojames
    14,050
    576
    I'm not aware of a how to for this.
    Now's your opportunity :icon_thumright:
  6. hades-
    9,481
    646
    yep get in there and take some nice pickys
  7. murran
    murran Well-Known Member
    1,545
    39
    could you take a picture of the switch? it might jog my memory of where it fits.
  8. Gstar51
    Gstar51 Member
    79
    Got the Haynes coming on mon. Replacement thread coming soon with pics.
  9. Slinepete
    Slinepete Member
    314
    Hi did this ever get a guide or can you advise me where the switch is located and how it was to do cheers Pete
  10. pauldazzle
    pauldazzle Well-Known Member
    1,166
    87
    It's on the passenger side of the gearbox. 5 min job if you have a ramp.
  11. Slinepete
    Slinepete Member
    314
    Thanks glad to hear its not a bad job hopefully get the part this week and get it sorted
  12. quattrojames
    14,050
    576
    You could always do a 'how to' with some pics to help subsequent users in your situation ;)
  13. Mike.M
    Mike.M Well-Known Member
    2,483
    169
    You sure it's the switch and not broken wires at the plug end as that is a common fault with VAG cars
  14. Slinepete
    Slinepete Member
    314
    Sorry what do you mean by plug end actually at the lights or the plug to, the switch il check that first not had chance to order switch yet anyway.
  15. Mike.M
    2,483
    169
    The plug at the switch end.
    The vibrations and engine movement over time break the wire internally really close to the pins in the plug and an early sign is flickering reverse lights when revving the engine.
  16. Mike.M
    2,483
    169
    It's actually quite rare to have a broken reverse light switch as the mentioned wires a the main culprit.
  17. Slinepete
    Slinepete Member
    314
    Aaa thanks for that might get a chance to look tommorow would I be able to see it just from jacking the car up or should I borrow some ramps cheers mj
  18. Slinepete
    Slinepete Member
    314
    James if I do sort it il do a little write up so people know where it is and if it's the wires or the switch itself
  19. Slinepete
    Slinepete Member
    314
    Anyone know if I could get to it just by jacking th car up as I might tackle this tomorrow if rain holds off.
  20. Mike.M
    2,483
    169
    Should be able to mate, but use axle stands...........small ramps would be better if you have access to them.
    The switch is located on the passenger side right above and about 2 inches behind your inner CV joint.
  21. Slinepete
    Slinepete Member
    314
    That's spot on cheers Pete
  22. Mike.M
    2,483
    169
    It may vary slightly from gear box code, but gives you a rough idea of location.
  23. Slinepete
    Slinepete Member
    314
    Still can't find it feel a right thicko keep asking I've looked all around passenger side could it be on the driver side for some reason mine is not a Quattro if that makes a difference
  24. many_methods
    many_methods New Member
    I know this is an old post but needed this info myself the other day so here goes:
    On my one (A4 B6 1.9Tdi 2003) the switch is accessible from the driver's side. (I've got a feeling that the pics earlier in this thread may be taken from another thread on different forum which I believe features a left hand drive car as the position of the fuse box appears to be a mirror image of mine). Therefore the reference to passenger side above might not be correct? I appreciate it may differ depending on what gearbox is installed.
    Anyway, on my car I needed to remove the airbox. Then stuck me head in the gap and peered as far back as I could (as per pic below).
    The switch is a nightmare to access and I couldn't get a screwdriver in there to unclip the wiring. In the end I taped an allen key to my thumb so that I could hook it onto the plastic clip once I'd stuffed my right arm all the way into the engine bay. Got the clip off and that solved the problem of the reverse lights staying on. However, it does leave you with no reverse lights at all!
    Not sure how the hell to get the actual switch unbolted from the block. Its a nightmare getting any tools in that far. Probably easier just to fit your own microswitch to the actual gear lever and wire it in to the electrics!! Not, perhaps, what your local Audi technician would recommend though.
    Anyway it started raining and was getting dark so I've given up trying to get the switch out. If anyone has any suggestions... that don't involve dropping the box out or removing the exhaust manifold... then please let me know. : )
  25. Slinepete
    Slinepete Member
    314
    I ended up taking mine to a local garage in the end and your right about them pics it was opposite side
  26. SuperV8
    SuperV8 Member
    70
    12
    Mine too was on the drivers side! 1.9tdi quattro. 2004.
    Changed it recently. I found it easiest to get at it from underneath having removed the rear under tray. You'll need a large spanner, I think something like 22 or 23mm.
    My switch had a broken return spring, so the reversing lights just stayed on.
    There are a couple of different switches so double check you have the correct one. Mine was also listed against RS4's and R8's but was the same part as mine.
    I used Audi PN 01E941521B. This is a two pin connector with long connector body. ETOS listed 01E941521A against my car but they are both the same part.
    Tom.
  27. bo0557
    bo0557 New Member
    27
    Bumping up an old thread!!!
    ive got the same issue now in the sense that my reverse lights stay on when driving..
    Ive got a B7 A4 3.0 quattro with the 6 speed manual - can anyone please tell me the part number for reverse switch please!!!
