Reverse light / park sensors
mrandyt Nov 2, 2013
  1. mrandyt
    mrandyt Member
    54
    I've had this problem a week or so now when I put it in reverse and it just sounds a long beep however last night I saw that the reverse lights are not coming on! Could this be a faulty reverse switch? If so where is this located, anybody else had this problem? Also the Park sensors are factory fitted.
  2. MattUK
    MattUK Member
    97
    17
    Hi
    The long beep means theres a fault.. You should get the car scanned to see what the error code is..
    Matt
  3. mrandyt
    mrandyt Member
    54
    Ok thanks I'll give that a try
  4. leegsi
    leegsi Active Member
    489
    57
    Is it an auto or manual?
  5. mrandyt
    mrandyt Member
    54
    Manual 2.0 Tdi 2006
  6. g00se
    g00se Active Member
    268
    26
    weird - just yesterday i had someone tell me that my reverse lights were on whilst i was crawling forwards in traffic.. also my parking sensors kept randomly beeping at me.
    in the end i pulled over and took the reverse light bulbs out (before i got a pull, or melted the bulb holders!)
    hopefully its just a sticky switch on the gearbox
    goose
  7. mrandyt
    mrandyt Member
    54
    Good luck with fixing your problem!
  8. g00se
    g00se Active Member
    268
    26
    Cheers - you too!
    EDIT: Had it on a ramp yesterday, and the switch has failed.. new £18 switch ordered, and should arrive Monday :)
    goose
