Reverse Camera With & Ami Installed - PLEASE HELP!!!
Chris Coates Apr 13, 2013
  1. Chris Coates
    Chris Coates Member
    97
    Hi all in Oz ive been told its impossible to have my 2010 A3 2L Tdi installed with a reversing camera,
    i have retro fitted The latest RNSE LED Screen and audi AMI, how ever i cant find a reverse camera kit,
    before i fitted the AMI i had an after market reverse camera and a module with Rca on it and i could use the camera but only from
    selecting it from the media button and then the input,,
    Genuine Audi RNS-E Highline Reverse Camera with Guidelines Supply Fit
    the above link claims they have a kit he can post me, and that will work on my rnse,with my ami and even work when i select R and even give me the lines that move when you move your steering wheel,
    if someone can help me out who has fitted this or have an option for me, im willing to go with it, but i need to keep my audi ami and my rnse, i dont even mind if i have to select the input to get it to work, but want them to all work,
    PLEASE PLEASE PLEASE :)
  2. vsantos69
    vsantos69 Member
    40
    Hi,
    i do have an OEM rvc working with my mk2 radio, all parts bought on the ebay ;)
  3. Ash187
    7,489
    741
    It can be done, you need the R8 reverse camera module along with wiring and the genuine Audi reverse camera and A6 camera holder. all that combined with the correct coding should get it working.
    Kelza likes this.
  4. Chris Coates
    Chris Coates Member
    97
    Hi guys great to hear: now would it be possible to grab those part numbers or dose anyone know where i can get the kit together apart from the link i supplied?
    Also guys is it possible to have the AMi still wired up with the camera? Vsantos69 have you got it all connected with AMI?
    thanks heaps for the help, this is a mod ive always wanted to achieve.
  5. Chris Coates
    Chris Coates Member
    97
    Hey guys where do i order these parts at a good price? and what coding do i need?
    PLEASE:)
  6. vsantos69
    vsantos69 Member
    40
    Hi, like i said above i bought all parts on the ebay. I'll see the PN's later to you...
  7. Chris Coates
    Chris Coates Member
    97
    Thank you Vsantos69
  8. vsantos69
    vsantos69 Member
    40
    Here you have:
    You can find more info here: Rear view camera retrofit | Audi Forum
    And here you have some search ;)
    4L0 980 551 | eBay
    The camera retaining clip and tapping screw you can buy it at your audi dealer because they are cheap. You need further the cable to switch on all this, i bought it on kufatec site's. About the reverse camera module i didn't find any at ebay right now but with patience it will appears.
    Of course you should have anyone to ensemble all this :D, or if you think you can manage it, go ahead ;)
  9. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    I'm interested in this.
    I have AMI (retrofitted) and MK2 193 LED RNSE (also retrofitted).
    Chris, did you ever find a solution for keeping the AMI and genuine RVC?
  10. Chris Coates
    Chris Coates Member
    97
    bought kit from vwcruise, its expensive as sin, has all the stuff, and he makes install instructions to your car and what you have, so less headache.
  11. BenC00
    BenC00 Member
    106
    Can this set up be fitted to a 3 door 8P or only sportback 8P?
    I have found a couple of different OEM RVC modules, one if from an A5, does anyone know if that will provide me with the trajectory lines or if this is only possible from the R8 module? (i'm having trouble locating an R8 moduel...)
  12. a6_chris
    1,883
    160
    Can work on a 3dr too. You definitely need the R8 module for the RNSE, no OEM alternatives. Part number begins 420.
    Do a search on here for 'rvc' and you'll find it.
  13. BenC00
    BenC00 Member
    106
    Thanks for the quick reply, I'll try and track down an R8 module from somewhere :)
  14. vsantos69
    vsantos69 Member
    40
    I have an 3dr A3 and it's working perfectly ;)
    You 2 chances. One is find this 420 910 441 - reverse camera module but you will not have the optical parking system (OPS). You you want this one you will need the 420 910 441 A however i never saw one being sold on ebay.
    The OPS does this:
    Sorry by the bad video but haven't done one better yet :D and, by the way, the only thing that's missing to all working perfectly is the calibration of the camera that i'll go to an audi dealer to work it out...
    BenC00 likes this.
  15. BenC00
    BenC00 Member
    106
    Thanks for the confirmation :)
    I don't have OPS so i'll keep a close eye out for a 420 910 441 module, how much should i expect to pay?
    I have read in several places that the module is around 200EUR from Audi...
  16. vsantos69
    vsantos69 Member
    40
    the 420 910 441 A cost to me 265 € and it wasn't at an local audi dealer. I've selled the one without letter in the end at ebay by 155 € including dilevering cost.
    One thing that doesn't work at the 420 910 441 (the one with the A at the end have it all working) is the 2nd parking function (you can see it at the righ upper corner in thd radio but it doesn't do anything). I can show it to you if you want (need to make another video).
    Regards.
  17. BenC00
    BenC00 Member
    106
    What is the second parking function? Remember, i do not have OPS :(
    Would you mind sharing the video please :) :thumbsup:
  18. BenC00
    BenC00 Member
    106
    I have managed to source a RVC camera module :) ... could someone confirm if "4L0 827 574 3F2" is the correct part needed for a 3 door A3 8P3 please?
    Oh and also the loom required from Kufatec, is it Wireing Harness rearview camera Audi A3 8P-39389
    Does it connect the camera to the RVC module and then to the RNS-E?
  19. a6_chris
    1,883
    160
    No. That's for MMI Most - you need the r8 module 420 etc
  20. BenC00
    BenC00 Member
    106
    Sorry, maybe my post wasn't very clear; i have purchased a 420 910 441 A (RVC Module) but need to get the door handle / camera holder, will 4L0 827 574 3F2 fit my 3 door or will it only fit a sportback? :thumbsup:
  21. BenC00
    BenC00 Member
    106
    Bump.... :superman:
  22. BenC00
    BenC00 Member
    106
    I now have my possession RVC Module '420 910 441 A' but need to order the door handle / camera holder - Could someone please please confirm if handle with part number '4L0 827 574 3F2' will fit my 3 door 8P3?
  23. vsantos69
    vsantos69 Member
    40
    Hello, sorry not have replied yet.
    And yes, that is the correct part number, i install it in mine 3 doors 8P :D It's the same for sportback or 3 door 8P.
    This is the harness correct Kufatec R8 Harness, i bought it to retrofit the RVC, PDC and RVC module.
  24. STYLEZAU
    STYLEZAU Member
    47
  25. vsantos69
    vsantos69 Member
    40
  26. Ash187
    7,489
    741
    that part is brand new from audi around £60
  27. BenC00
    BenC00 Member
    106
    Small update: RVC module is connected, but could someone confirm if my coding is correct because my RNS-E is not switching to the RVC when the reverse gear is selected:
    RNS-E 193G: (Bose, BT, MFSW, RVC, AMI)
    Coding: 0709725 (I had to code as R8 to be able to enable RVC in CH4 below)
    Adaption: CH4 = Value 2
    RVC Module:
    Coding: 1000012
    RVC Module enabled in CAN gateway, I am able to communicate and view values when reverse gear is selected etc)
  28. BenC00
    BenC00 Member
    106
    Is there a way of manually switching to the RVC so I can verify that it is actually working? A secret combination of button holding maybe....?
  29. vsantos69
    vsantos69 Member
    40
    I didn't answer you yet because i don't remenber my sttings on the radio and rvc module. I remenber that i had to make the radio re-start to the camera work on pushing radio+???(some other button of the rns-e that i don't remenber) and then it worked fine.
    When the radio doesn't switch with the reverse gear, i think it shows the image on the media button.
    Try in the adaptation, module 37, configurate to lambo and see if it works.
    I'll try to see my configuration to put it here...
  30. BenC00
    BenC00 Member
    106
    UPDATE: Okay, so I got this working on my 2009 A3 eventually, I’ll share the information that I collected during my install:
    Vehicle Details:
    2009 A3 2.0 TDi S Line DSG CBBB 3 Door
    Retro Fitted RNS-E, AMI, BT
    8P0 035 193 G (RNS-E MY2012)
    1K0 907 951 H16 (Factory fitted CAN Gateway w/ RVC support)
    Parts Purchased / Required:
    VCDS w/ Licensed Cable
    1 x Kufatec RVC A3/R8 Harness: Wireing Harness rearview camera Audi A3 8P-39389
    1 x Fakra Type Z 200CM extension cable (eBay)
    1 x Fakra Type Z Male Connector (eBay)
    1 x Fakra Type Z Female Connector (eBay)
    1 x 4L0 980 551 (Rear View Camera)
    1 x 4L0 827 574 3F2 (Door handle for 5DR & 3DR models)
    1 x 4L0 980 553 (Camera retaining clip)
    1 x N 909 159 01 (Camera retaining Screw)
    1 x 420 910 441 A (Reverse Camera Module with OPS) (I plan on retrofitting OPS later....)
    OR
    1 x 420 910 441 (Reverse Camera Module without OPS)
    Coding:
    8P0 035 193 G (RNS-E 193G): (Bose, BT, MFSW, RVC, AMI, R8)
    Adaption: CH4 = Value 3
    RVC Module: (Audi, RNS-E, Standard Height Camera)
    Coding: 1000012
    Notes:
    - Initially I had issues with the RNS-E not switching to the RVC when reverse gear was engaged, I got round this by changing the adaption of Channel 4 on the RNS-E to Value 3.
    - RVC Module logs fault '03006 - Back-up Camera System not calibrated', this doesn't prevent the camera from working and the camera seems to be set up perfectly out of the box for an A3.
    - The Kufatec loom is roughly 150cm too short for RHD vehicles and comes with an incorrect Fakra connector for the Reverse Camera (4L0 980 551). I got round this issue by purchasing a Fakra extension cable with Fakra Type Z connectors, plus additional Male and Female Fakra Type Z connectors and extending the power cable for the Camera.
    Kufatec offered practically zero support for the incorrect coding in their documentation, harness being too short and incorrect Fakra connectors, I was far from impressed with their aftersales support.
  31. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,011
    548
    how much was a total cost for the parts?
  32. BenC00
    BenC00 Member
    106
    I'll have a dig through my receipts, although I'm afraid that total cost of this little project will scare me :puke2:
    The most expensive part is the RVC module, if you can source this via eBay, you will save $$$.
  33. S.
    2,011
    548
    ok sorry then no need to sum the cost.
    would love this cool mod but since i've got parking aid no need for that :D
  34. sabinx
    sabinx New Member
    Hello. I ordered all the parts from the list. The complete handle, camera and module have arrived, now I'm just waiting for the cable.
    I have one question regarding "- RVC Module logs fault '03006 - Back-up Camera System not calibrated', this doesn't prevent the camera from working and the camera seems to be set up perfectly out of the box for an A3."
    Have you calibrated the camera?
  35. Ash187
    7,489
    741
    Calibration is not needed on the a3, ignore the fault
  36. sabinx
    sabinx New Member
    Hello again. Thank you for your answer. I'm also interested in this.
    I have AMI factory fitted and RNSE 193G factory fitted
    If I am doing the RVC retrofit will this affect AMI somehow?
  37. hollow
    hollow Well-Known Member
    1,404
    162
    i just bought a cheap china camera with loom and a £30 intyerface that connects to the wiring on the rnse ,it also senses reverse through the can bus signal so auto switches camera when reverse is selected , also has reverse lines as well
  38. golfmk5
    golfmk5 New Member
    12
    Hi,
    I was wondering if you could please help me out with my RVC install.
    I already bought and fitted all the needed parts (with the R8 module part number 420 910 441).
    my problem is that when I change my coding in channel 4 at the adaptation to 3 the RNS-E does not switch to the RVC image(tried also to code the rnse to R8 instead of a3 and it made no difference). and I get the following fault code
    Sunday,28,December,2014,11:18:28:11344
    VCDS Version: Release 14.10.0 (x64)
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Control Module Part Number: 8P0 035 193 B HW: 8P0 035 193 B
    Component and/or Version: RNS-E PU EU H04 0220
    Software Coding: 0705757
    Work Shop Code: WSC 66565 257 00032
    VCID: 2F6DCF21BE311C59C61-807A
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 91062 km
    Time Indication: 0
    Date: 2014.12.28
    Time: 11:17:14
    Freeze Frame:
    Bin. Bits: 00001000 00000000
    Bin. Bits: 00000000 00000000
    but when I change it to 1 value (lamborghini mode), I can see the rear view camera image.
    originally I bought this wiring loom for the camera:
    http://www.aliexpress.com/snapshot/6324085281.html?orderId=64443234450906
    but when I received it I notice that it is not the same connector as the RNS-E 32 pin connector, so I modified it according to these two diagrams:
    the diagram of the of a golf/passat RVC(the ones in the red were present in the wiring loom that I received)
    This is the wiring loom of the RVC in an audi R8
    this is the before and after:
    in general I connected all the wiring in the R8 diagram except for the one from t54a/25 to t32f/14. its the same wire as the yellow/black wire in the passat diagram, which was not present in the loom I received, also according to the pin description on the RNSE it is "SHEILD GND". so I doubt that it is causing the problem for me, I am quit sure that it is only related to the image quality which is great already.
    I also tried yesterday to see if my friend's 193G RNS-E will work as should but it also gave me the same fault code of "Functionality limited due to Communications Disruption"
    this is an auto scan of my car that I ran today :
    Sunday,28,December,2014,11:34:44:11344
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.10.0.0 (x64)
    Data version: 20141022
    Workshop Code: 257 66565 000032
    VIN: WAUZZZ8P09A063249 License Plate: MY CURRENT FAULT CODES
    Mileage: 91060km-56582mi Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 47 52 55 56 6C
    77
    VIN: WAUZZZ8P09A063249 Mileage: 91060km-56582miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    6C-Back-up Cam. -- Status: Malfunction 0010
    77-Telephone -- Status: Malfunction 0010
    Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
    Part No SW: 8P0 907 115 AC HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0010
    Revision: 5BH16--- Serial number: AUX7Z0H9FNK0Z6
    Coding: 0103000C180F0160
    Shop #: WSC 66565 257 00032
    VCID: 73E50351129978B9629-8026
    1 Fault Found:
    001089 - EVAP Emission Control Sys
    P0441 - 002 - Incorrect Flow - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 90574 km
    Time Indication: 0
    Date: 2014.12.16
    Time: 21:36:21
    Freeze Frame:
    RPM: 760 /min
    Load: 12.5 %
    Speed: 0.0 km/h
    Temperature: 90.0°C
    Temperature: 24.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.970 V
    Readiness: 0000 0001
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
    Component: ESP MK60EC1 H45 0107
    Revision: 00H45001
    Coding: 14428012092800FD280D01E8902200413800
    VCID: 000F5C9D932F53216FB-8055
    No fault code found.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
    Component: KlimavollautomatH09 0100
    Revision: 000424 Serial number: 8P0820043BG
    Shop #: WSC 00000 000 00000
    VCID: 72EB06556D8371B169F-8027
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number: 00000009040095
    Coding: E98E1F0780141380EF00000A4F00000000084E056406000F002000000000
    VCID: 489F84BD3B9FAB61E7B-801D
    Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 66565
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00150573
    Shop #: WSC 66565
    Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
    Part No SW: 5KD 919 475 HW: 5KD 919 475
    Component: PARKHILFE 4K H07 0001
    Revision: -------- Serial number: 05211332100336
    Coding: 000001
    VCID: 071D4781B60164192E1-8052
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003000000000
    Coding: 303142413039303030344A55304C38503053
    Shop #: WSC 06314 000 00000
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 499981B9E8955269F85-801C
    Crash sensor for side airbag; driver side:
    Serial number: 34928RB40000469CFA0
    Crash sensor for side airbag; front passenger side:
    Serial number: 35028RB40000471899CO
    Crash sensor for side airbag; rear; driver side:
    Serial number: 35128RB40000469CF89
    Crash sensor for side airbag; rear; passenger side:
    Serial number: 35228RB40000471896EP
    Crash sensor for front airbag; driver side:
    Serial number: 35547RB4000047B1A09M
    Crash sensor for front airbag; front passenger side:
    Serial number: 35647RB4000047B1E47T
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0002142
    VCID: 4189999918A59A29205-8014
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    1 Fault Found:
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 932 HW: 8P0 920 932
    Component: KOMBIINSTR. VDO H18 0830
    Revision: D0H18006 Serial number: 2249H006002763
    Coding: 0005128
    VCID: 71E9095968854AA9905-8024
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Revision: H16 Serial number: 2700K08A110D1E
    Coding: E9A31F065046020100
    VCID: 3561FD495C6D26898CD-8060
    Address 22: AWD Labels: Redir Fail!
    Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
    Component: Haldex 4Motion 3016
    Coding: 0000005
    VCID: 4385939102B98839329-8016
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H18006 Serial number: AUX7Z0H9FNK0Z6
    Shop #: WSC 00001 730 99338
    Part No SW: 8P0 035 193 B HW: 8P0 035 193 B
    Component: RNS-E PU EU H04 0220
    Revision: 0000006S Serial number: AUZBZ7K6106396
    Coding: 0205757
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Component: Tuer-SG H03 0060
    Coding: 0000020
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 234 2301
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2A5BDE3585D3797111F-807F
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1880200002586D2D8505488AC677
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
    Component: AB2 SUBWOOFERBOXH30 0160
    Revision: 00006 Serial number: 30659850313849
    VCID: 3467C04D57173F81BB3-8061
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Coding: 0000020
    VCID: 4487908D07B78F010B3-8011
    Address 55: Headlight Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 J
    Component: Dynamische LWR H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000013
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205757
    Address 6C: Back-up Cam. Labels: 420-910-441.clb
    Part No SW: 420 910 441 HW: 7L6 907 441 C
    Component: J772__Rearview 0040
    Revision: --H13--- Serial number: 525PA8-J8960AM
    Coding: 1000012
    VCID: 499981B920955269F85-801C
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 14
    Time Indication: 0
    Freeze Frame:
    Invalid
    Invalid
    Invalid
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 336 HW: 8P1 862 336
    Component: FSE_256x BT H41 0650
    Revision: 00000000 Serial number: 00000005036709
    Coding: 0011477
    Shop #: WSC 01236 785 00200
    VCID: 75E13D491CED66894CD-8020
    1 Fault Found:
    02503 - Output Wire to Radio
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 54
    Mileage: 90979 km
    Time Indication: 0
    Date: 2014.12.27
    Time: 18:15:43
    End-------------------------(Elapsed Time: 02:11)--------------------------
    also I retrofited to my car an OPS system from VW
    this one:
    http://www.ebay.com/itm/261384288370?_trksid=p2060778.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    and I did not manage to get the OPS to work in my RNS-E unit(but I am not concerned about that right now and I don't think it is causing any problem with the RVC install).
    Thanks in advance for all the help, I am out of ideas at the moment :(
    Eran
  39. golfmk5
    golfmk5 New Member
    12
    one last thing
    I am thinking of connecting the rear view camera power cable from the R8 module to the RNSE lamborghini mode RVC signal, this way the function will work almost the same as it should, but I still would like to try and get everything work properly.
  40. j.urgen
    j.urgen New Member
    Hello, i don't get it working
    i Have the same parts but it's not going too work.
    RNS-e 193 G and
    1 x 4L0 827 574 3F2 (Door handle )
    I coding it but see nothing on the screen.
    Coding:
    8P0 035 193 G (RNS-E 193G): (BT, MFSW, RVC, AMI, R8)
    Coding: 0729725 (I had to code as R8 to be able to enable RVC in CH4 below)
    Coding: 1000012
    Connections a good but don't now it anymore.
    Can somebody help me please.
    Thank you very much.:)
