REV D Recirculating Valve - Where From?
Lovegroover Jul 23, 2013
  1. Lovegroover
    Lovegroover Member
    155
    Where do you buy a Rev D recirculating valve from?
    I phoned Audi and they said the only part that exists on their system is the Rev G (which I already have - 58plate S3).
    I then looked on Awesome's site and they have 2 Rev D's. A pieburg one and an VW/Audi oem one. Anyone know the difference as they sure as hell don't I've asked them 3 times. My standard Rev G is made by Pieburg so i'm mega confused?
    Just want to get sorted so that when I get my remap - all is well ;-)
  2. Aidy06
    Aidy06 Member VCDS Map User
    412
    19
    I got a Pierberg one from eBay, think it was £45 including postage. Worked a treat
  3. R34nel
    R34nel Active Member
    323
    33
    I've been running the standard old diaphragm type one (2007 s3) at stage2+ for 6 months now and it seems fine, I check it periodically and no splits so far, I just figured I'd swap it if it failed, any other reason to change?
  4. Lovegroover
    Lovegroover Member
    155
    I was under the impression the piston valve operates better under raised pressures. Being that by design it is the more 'engineered' solution. I've checked my Rev G and it's not split, yet. But as I said I'm soon to remap.
    Just figured from all the posts I've read the diaphragm valve is worth distance checking a.s.a.p
  5. S3AMK20VT
    S3AMK20VT Member
    170
  6. gilberto
    gilberto Member
    156
  7. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    GSF do them, but need to call to obtain the right part as from memory it's not listed on the website.
  8. Lovegroover
    Lovegroover Member
    155
    Just phoned my local VW dealer and they recognized the part no. £60.79 inc VAT with them. Thanks for your help guys looks like FR&R are the men, will just have to wait for delivery.
  9. Jack_tdi
    Jack_tdi Member
    287
    12
    £45 from awesome gti... Not sure on delivery times or cost though...
    Sent from my iPhone using Tapatalk 2
  10. Sevv
    Sevv Pushing the limits..
    1,323
    118
    they are both the same one has the Audi VW emblem on them the other one doesnt... they are both mate by pierburg
    awesomegti do free shipping if not mistaken on all UK mainland orders
  11. AwesomeAl
    AwesomeAl Member
    269
    Hi there,
    I find your comment a little bit harsh. I myself replied to an e-mail from someone the other day with this exact same question and have checked to ensure all my colleagues are aware of this too (which they are). Did you call or e-mail? If you called, Can you drop me a PM with your phone number so that I can check with the recorded calls?
    Anyway - I shall answer this again in case anybody finds this as a result of a search.
    The Genuine OEM Revision D Valve that we sell comes direct from Volkswagen themselves.
    The Pierburg Revision D valve comes from an after market parts supplier.
    Both of these valves are manufactured and assembled by the same people, in the same factory and are both made by Pierburg.
    The difference is quite simply the Supplier and the box that it comes in.
    Even to a point that the Pierburg valve has the genuine VW/Audi part number scratched off it and a sticker placed over it.
    Hope this helps.
    Regards, Al.
    Awesome Ltd.
  12. Lovegroover
    Lovegroover Member
    155
    Sorry not meant to be harsh, I have no wish to try and put your company down. I have used you many times over what must be the last 10yrs and never had any problem with your service. Hence why you were my first port of call.
    However I did use your 'Live chat' question service 3 times to try and get an answer, once admittedly was out of hours - which was the one that you replied to. By that time the above conversation had already happened and I had already purchased from FR&R.
  13. AwesomeAl
    AwesomeAl Member
    269
    No worries :)
    Just give us a buzz in future if your not getting any response on the live chat.
  14. geforce189
    geforce189 Member
    53
