Rev counter not working.
guysy Aug 8, 2010
  1. guysy
    guysy Member
    My mate has a 2004 quattro 3.2, Since he's had the car the rev counter hasnt worked at all,
    Is there any common problems with this?
    Or anything sensor wise that can be checked or cleaned?
    Thanks.
  2. guysy
    guysy Member
    Anyone please?
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    Its hard to know without a scan using vagcom. Where are you? Maybe there is a fellow member nearby with the lead that could help you out.
  4. NHN
    29,594
    1,782
    The needle mechanism could of come of the wheel in the back of the cluster, need to take it apart to check tbh.
  5. guysy
    guysy Member
    Cheers fellas,
    Im doing research for a mate who doesnt have time for posting on the forums,
    Any guides for taking apart a 3.2 2004 quattro dash please?
    Hes based in loughton, Essex...Anyone close?
    Thanks.
  6. guysy
    guysy Member
    Anyone got a link for taking an a3 2004 quattro dash off please?
  7. Khufu
    5,704
    31
    release the steering wheel adjustment latch & pull wheel out & down as far as you can the trim directly under the clocks pulls off revealing two bolts. Undo these and wriggle clocks out. The is a single multi-plug connected to rear, release the pink latch by unclipping the latch turning it through 180 degrees while pulling out multiplug. After doing it once its a 2 min job.
    If its the cluster thats faulty, maybe its time to upgrade ;-)
    http://www.audi-sport.net/vb/showth...r-DIS-fitted-to-04-8P&highlight=white+cluster
  8. guysy
    guysy Member
    I appreciate the help mate cheers.
