Return to A4
samuelt Feb 20, 2011
  1. samuelt
    samuelt Member
    383
    HI All
    Been away from the A4's for a while as i had a A3 but just been out yesterday and bought a 2003 A4 2.5tdi Convertible with Multitronic (yes i know may be spelt T R O U B L E). It has done 73k and had a new gearbox and ECU at 72k so hopingfor the best! I have though a couple of questions some of you may be able ot answer, they are not all cab related.
    The car has full electric leather seats, but the drivers does not go up or down or tip. It makes lots of motor noises but does nothing... any idea?
    The Concert CD player volume button is faulty, when you turn the volume up it sometimes goes to 0 then 1 then 0 then 7. IS this common? can it be fixed?
    Is it easy to replace the glovebox door? i only noticed today but it has been glued at the hinges and that is failing.
    Did all of the cabs come with extendable boot loaders fro the roof? and should the cogs of the motors be visable, looks like 2 pannels are missing that should hide these?
    Thanks for any advice.
  2. allyp
    allyp Member
    222
    The seat maybe like a ford it has a motor with a worm screw on it ,it will need replaced if its the same
  3. hades-
    9,481
    646
    seat is a worn screw rod dont know real name for it prety easy fix as above like the fords always fail
    there is a fix for the radio dont always work id just replace
    glovebox door very very easy to swap round
    take a pic of the cogs theres someting missing as theres always covered
  4. Cabbyfan
    Cabbyfan Active Member
    840
    34
    There are a couple of gloveboxes on ebay at the min.
    As for the extendable boot loader for the roof, everything is pretty much covered. If you can post pics I will compare it to mine if you like. The lever that moves left to right or right to left to move the big flap is prone to failing and is very expensive to fix........
  5. samuelt
    samuelt Member
    383
    Hi Guys
    Thanks you for all of the replys!
    Is there any 'how to' on this website or others that details how to fix the seat?
    I will keep an eye on ebay for the glovebox as the ones at present are the wrong colour
    regards the stereo, i may look for a new one!
    bex101 i have had to set google picasa to get this pic up so hope it works!
  6. hades-
    9,481
    646
    hmm im sure mine wasnt like that
    but when the flaps down you cant see it
    iv got one in the yard i can check tmoro but im sure someone with 1 to hand will pop along soon
  7. Cabbyfan
    840
    34
    Hi, just took a couple of piccys of mine for you, looks like you got a bit missing I'm afraid....
  8. samuelt
    samuelt Member
    383
    thanks for taking the picture, it looks like the bits are misssing :( not going to ask Audi how much i think i would faint, may contact a breaker.
