Retrofitting Coming Home Feature
Wrath Feb 27, 2010
  1. Wrath
    Wrath Well-Known Member
    1,196
    41
    Found a number of units on the Gernam ebay selling units that do the "coming home" lights feature. Anyone know if these are genuine Audi or if it's straightforward to retrofit? Presumably you need the coming home button that sits near the headlight switch.
  2. comc
    comc VW-7 Audi-2
    54
    Hello Wrath
    Try this link for information which may help you. Not sure if it is applicable to your specific model but it may just save you a few quid.
    http://audiretrofit.quinlivan.net/
    Scroll down a bit to find the relevant guide with pictures.
  3. Wrath
    1,196
    41
    Cheers for that, presume it's the same for the B7. Don't suppose anyone here has done this?
  4. Chris79
    Chris79 On my 3rd A4! RS4 next???
    159
    Any luck? Sounds really useful.
    Chris
    Sent from my iPod touch using Tapatalk
  5. Wrath
    1,196
    41
    Not confident enoguh to try it as I haven't found an actual B7 thread and each model is slightly different.
  6. mattb1434
    mattb1434 New Member
    21
    hi
    Im about to start retrofitting this today along with the auto dim mirror and rain sensor, i had a new windscreen fitted yesterday so i could fit the sensor and mirror just got to do the wiring.
    I'll try and to a HOW TO while im doing it and post it on here.
    matt
  7. jwhat
    jwhat Member VCDS Map User
    541
    A how to would be great Matt
  8. Wrath
    1,196
    41
    That would be fantastic! Where and how much did you get the windscreen?
  9. Wrath
    1,196
    41
    Any news on this?
  10. dan_the_v8man
    dan_the_v8man Member
    66
    I've come up with a cheaper way of doing this that can be done on any car.
    When you unlock or before you lock the interior lights come on. Take a feed off one of the interior lights, feed a relay which in turn switches your headlights on. Possibly add a switch to disable the function if needed.
  11. jwhat
    541
    I wonder if you could use the original switch in the circuit you suggested? It's the one on the left
  12. Wrath
    1,196
    41
    Looking at the B6 thread, apparently the relevant wires are there, just tucked away. If that was the same with the B7 then all you need is a replacement switch, in my case a switch with both headlight levelling and CH and plug the wires into it.
    However, I am not confident enough with wiring so would prefer someone else to do it :)
