Retrofitted xenons help needed
chrisa4quat Feb 11, 2012
  1. chrisa4quat
    chrisa4quat Active Member
    970
    Just wired in my xenons (which have been fitted weeks) I have changed the coding etc but I'm having a problem with bulb warning light on one setting or no flash on the other setting. Can anyone assist me please?
  2. chrisa4quat
    970
    Anyone? Bulb warning light is doing my head in
  3. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,286
    10,249
    Maybe you could pm nigel, user (NHN) he is very knowledgeable on these thngs. He may be able to advise you.
  4. 50k
    50k Member
    76
    10
    Did you manage to sort it??
  5. chrisa4quat
    970
    Not yet. My high beam works on halogen coding but only with dip be on not sidelights or no lights. Bulb warning on. Or I can get no bulb warning light on no beam on dip lights and dip lights flashing as beam with no lights
  6. DTM-Edition
    DTM-Edition New Member
    How did you wire them up? I know they have different pin counts kufatec.de do a direct fit loom if that helps
  7. chrisa4quat
    970
    I wired them up with a supplied loom. Maybe it's naff. Maybe I need a control unit. I don't really know
  8. lenti
    lenti 7th Gear
    87
    37
    id id retro fit mine from halogen to bixenon,
    so what youre saying is. When you have the High beam does not work and you get a warning?
    if it is that then you have connected them wrong, or coded them wrong. the 2 small yeallow pins must be connected rigth for the highbeam to work. and also the code must be right.
    use this code and dont change the thre first codes in VAG
    Euro Headlights & DRL
    Module 09 (Central Electrical), recode to ###21
    i think the origininal code for the halogen is 01012
    If u have the code 21 then the lights work but if not the hight beam then you have connected the small yeallow pins wrong. i did it to after changing it it worked like a charm :D
  9. chrisa4quat
    970
    My high beam works with dip beam on but not with side lights or
    Lights off. You can hear the lids opening but no light output
  10. lenti
    lenti 7th Gear
    87
    37
    Wich code did you use on VAG Rosstech?
    maybe it is something wrong with the kufatec cable?
  11. chrisa4quat
    970
    I don't know If the cable is Kufatec? I have tried all sorts of coding. It is actually coded with halogens at present cos works best that way - confused
  12. lenti
    lenti 7th Gear
    87
    37
    i wouldnt use halogen code wioth xenon you can brick ure headlights. beacuse xenons need more power than halogen and i think it is dangerous to use the halogen code on xenon but im not sure.
    Try the code i told you in the end with ###21, if that does not work then its something wrong with the lights or the kufatec cable
  13. chrisa4quat
    970
    The lights seem to work fine. Maybe the wiring. I tried the right coding and high beam does not work on dip beam. And dip beam flashed as high beam when lights off
  14. lenti
    lenti 7th Gear
    87
    37
  15. chrisa4quat
    970
    It came with the lights
  16. lenti
    lenti 7th Gear
    87
    37
    if ure using the code ###21 and that does not fix this, then something is wrong with the connections, or you did connect the 2 small cables that needs to be connected under the steering wheel wrong.
  17. chrisa4quat
    970
    The coding doesn't work. I connected them to pins 16 & 18 from memory
  18. lenti
    lenti 7th Gear
    87
    37
    You need to code them so that the car uses them as Xenons and not halogen, you can destroy the lights and also the electrical system in ure car if you do not change the codes.
  19. SinghB7
    SinghB7 Active Member
    525
    68
    i'm having problems with my coding, when I come to change the code from halogens to xenon it dosn't save. I am using the write code, changing from halogen to ***21 xenon code.
