Retrofit S3 Manual Aluminium Pedal Set
funguf May 3, 2007
  1. funguf
    funguf Sunday Driver
    81
    Hi All,
    Has anyone tried to retrofit the S3 Manual Aluminium Pedal Set to their A3?
  2. funguf
    81
  3. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    9
    yup. very simple install. I bought them from my dealer for £80.
  4. Boydie
    Boydie Guest
    the clutch and brake pedals are simple
    the accelerator is a litte more tricky
    you can be the sensible person and use a flat headed screwdriver to release the clips at the front bottom section of the accell pedal - you will see what i mean if you look at the new S3 pedals
    takes a bit of leverage but easy enough to remove
    there is a torque screw also on the left hand side of the pedal
    the wiring clip for some reason i found very difficult to remove but my friend had a go and within seconds he had it off - i dont know what i was doing!!
    other than that you can just rip it off (which my friend did because he is an asshole!) it still fits perfectly though for future replacement!
    hope this helps - cant wait for them to bring out the S3 dead pedal for RHD!! safety reasons my ****!
  5. EAGLE79
    EAGLE79 Member
    339
    Yes very easy fitting apart from the accelerator plug which was a git to get off, nearly removed my thumb nail. Me old man had a go and got it off fairly quickly and without breaking it.
    Generally nothing too taxing, see the audi accessories page linked above for easy to follow instructions
  6. wilko
    wilko Top Gear
    725
  7. si_reading
    si_reading Member
    168
    £80 is quite a good price when I got mine couldn't find them anywhere. I got some Jetta GLI Pedal imported from Germany cost me well over £80 lol.
  8. MarcQuinlivan
    2,539
    9
    i'll try to find the order later and get the part numbers so you can see if they are the same parts - they probably are.
  9. dm_irish
    dm_irish Member
    99
  10. A3NDY L
    A3NDY L On the Drive or On The Redline
    55
    I got mine from 'MarriedBlonde' on here. A little over £65 if I remember correctly including postage, and they are the proper Audi S3 ones. They look great once they're in.
