Retrofit Rear Parking Sensors?
ryanstewart9 Sep 18, 2009
  1. M4ciek
    M4ciek New Member
    9
    retainer (holder) (2), buzzer (6) and these plastic pins (3), (7)
  2. -Ju-
    -Ju- Well-Known Member Team Panther VCDS Map User Audi S3
    2,373
    493
    Just resurrecting this thread rather than starting a new one.
    I'm doing this retrofit and up to press I have everything fitted apart from the final connections to the car. However when I've removed the fuse box I don't have any live feeds to fuses 8 and 18 as detailed in the Kufatec instructions, I do however have no.14 spare and it does state "fuse 14 automatic gearbox/park assist" on the fuse cover. Can I just wire into here with both of the wires or do I need to put them into separate, if so I don't have another spare in the fuse box without creating one.
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    iirc I didn't use the exact location either. I used a free slot that I could actually feed the connector into without ripping half the wires out to get access. I then marked it in the panel label.
  4. -Ju-
    2,373
    493
    I'm sure I'll be ok using 14, just not sure if I can stick both feeds to that or not :confused:
    Sent from my Atrix using Tapatalk
  5. Ash187
    7,505
    748
    lol you did it better than me! i just tapped into the rear canbus connections and tapped off power there... all working perfectly for a year now :)
  6. -Ju-
    2,373
    493
    Took both feeds to fuse 14 and bingo it all works:icon_thumright:
  7. -Ju-
    2,373
    493
    Just to add, taking both feeds to fuse 14 does work however it does throw a fault code. The confusion comes in that Audi have changed the fuse box fuse allocation a few times since the kufatec instructions were done and from 07 on, the correct fuses are 14 and 4, 14 being a blank and 4 a splice into the loom. All working now with no faults
  8. apoc_reg
    apoc_reg Member
    66
  9. MTRL
    MTRL Split Grill!
    459
    52
    Has anyone installed this type of parking sensor?
    MrWhItEwOlF and sliced like this.
  10. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    :lmfao:
  11. Ash187
    7,505
    748
    :lmfao:
  12. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3 It's my birthday
    3,078
    605
    Thats brilliant .lol
  13. apoc_reg
    apoc_reg Member
    66
    Haha nice!
  14. drgndb
    drgndb New Member
    Hi
    Do you fit the OEM genuine kits to VW's as well?
    I want an 8 sensor kit fitting on my golf if you are interested..
    Darren
  15. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Sorry for dragging this up again.
    I bought a PDC kit off eBay which is made up of 8P0 919 475 M, 4x sensors PN - 1S0 919 275 A and I bought both looms off Kufatec.
    PDC Park Distance Control-Rear Sensor Harness-Audi A3 8P& 8P-34478_M
    and
    PDC Park Distance Control -Central Electric Harness-Audi A3 8P &-34479_M
    Now the power loom has a ground, plug for the buzzer, CAN hi and CAN lo, a power connector pin like the end of repair wire and a single bare wire.
    I assume the single wire is part of the two feeds for the power? I've read this thread about 3 times now and I think I have digested everything to the best of my knowledge.
    CanHi and CanLo tapped into the CCM CanHi and CanLo and Ash seems to have got the power from there too?
    One thing that bugs me is that the sensors are stamped 2012 but with a VW logo and the PDC module is stamped November 2010 - hopefully these are correct.
    Could someone advise if I'm on the right track? Won't be jumping into this btw so appreciate any answers/advice given ;)
    Btw anyone who can guide me through the above, can have some beer tokens for their time :)
    I can solder and heatskrink, just need to get everything sorted first. Have ordered a copy of elsa off ebay.
  16. -Ju-
    2,373
    493
    Sounds like you have everything in hand, it is a fairly easy job tbh although I remember the Kufatec intructions were a little awkard to understand, a bit like Ikea instructions lol.
    I took the power all the way to the fuse box as I was happier doing that but I know others have tapped in elsewhere
    How are you fitting the sensors I take it they are the later type i.e. the smaller ones? Mine were the earlier type and I bought the correct bumper and had it sprayed up.
    Other than fitting everything I take it you have access to VCDS for the coding?
  17. a6_chris
    1,883
    160
    Yep I have genuine VCDS and the sensors are tiny, about 17mm in diameter.
    Could someone with etka check the sensors part number above are compatible with the module? The loom fits them fine.
    To save running wires to the front, could I do what Ash has done and got power from the CCM? Or would it be better just to do it the proper way and fusebox them?
    I have an ugly aftermarket kit fitted atm which I'll be taking out so won't know if the holes for them are bigger than 17mm as they sit on top of the bumper and aren't flush.
    I might need a new bumper or I might be lucky and the holes aren't as wide as the current sensors.
    Ignore the blue line.
  18. Wicked666
    Wicked666 Active Member
    584
    35
    a6_chris likes this.
  19. a6_chris
    1,883
    160
  20. -Ju-
    2,373
    493
    Yep as above they look like the retrofit kit that Audi dealers fit, had them on my first Audi. Not the most attractive looking and almost certainly will leave the holes too big!
  21. a6_chris
    1,883
    160
    Rats! Well my main priority is to get the wiring sorted and deal with the bumper later as I can leave them unconnected anyway.
    If I post my CCM details up could someone kindly look up on elsa which wire is which please?
  22. a3Shakey
    a3Shakey New Member
    At risk of proving myself a philistine with my second post, I have just bought a £65 Dolphin kit with four sensors, a control unit and buzzer. This is powered from the 12V feed going to the reversing lamp so doesn't have al the functionality of the OEM stuff but then you get what you pay for.
    I'm going to have to drill the bumper and tap into the reversing light. If that interferes with the canbus lamp warning, I already have some cabus resistors to solve that.
    Can anyone tell me the colour code for the reversing lamp 12V feed?
  23. Ash187
    7,505
    748
    its the blue and red cable on the tail lights loom... usually on the passenger side iirc
  24. a3Shakey
    a3Shakey New Member
    Many thanks Ash :)
  25. a3Shakey
    a3Shakey New Member
  26. a3Shakey
    a3Shakey New Member
  27. Breezey
    Breezey Member
    453
    Weren't red by any chance? i think you'll find that part number relates to the new OPS sensors not the retrofit ones never mind :sob:
  28. a6_chris
    1,883
    160
    Never updated this,
    Got everything fitted, painted and coded. Very happy with the result.
    Needed a new module though as the original one died.
    Code:
    Address 10: Park/Steer Assist (J446)       Labels: None
       Part No SW: 8P0 919 475 C    HW: 8P0 919 475
       Component: PARKHILFE 4K  H06 0101
       Revision: 11001001    Serial number: --------------
       Coding: 00010B
       Shop #: WSC 06751 128 28888
       VCID: 3E774636A9B799EEA6F-806B
    No fault code found.
  29. Walts2782
    Walts2782 Active Member
    243
    61
    Did you buy a new bumper or fit brackets to the old one in the end??
    Nice looking job by the way :icon_thumright:
  30. a6_chris
    1,883
    160
    Thanks!! Yeah bought a new bumper for £40 with factory PDC holes so no messing about.
    I'll post some better pics tomorrow in the light.
    Walts2782 likes this.
  31. a3Shakey
    a3Shakey New Member
    It turns out that's the feed to the red tail lights. I interpreted "on the passenger side" to mean the loom behind the main light cluster but it's apparent that there's no reversing light in the main cluster; it's all in the tailgate mounted cluster.
    so it's installed but for the moment not working until I can find a way of identifying the correct trigger wire :wacko:
    Can anyone help me please?
  32. Schlaag
    Schlaag Bwah
    486
    32
    Hi Chris, glad yours is working well. I'm going to the same to my 2011 S3.
    What PDC module did you replace your faulty one with?
    A couple of simple questions I hope
    1) Is the S3 rear bumper (main cover) specific to the S3 or does it share with other models? I think im going to have to get a bumper with the pdc holes and attached brackets
    2) I've heard about visual parking aid (graphic of car) also showing up on the RNS-E screen... has anyone ideas of this can be done on a 2011 car?
    thanks, great thread!
    Dave
  33. Sayam
    Sayam Well-Known Member VCDS Map User
    2,715
    637
    i believe that is called Optical Parking. as far as I know you need the front and rear sensors to make it work.
    i'm sure @NHN will be able to supply/fit the system
  34. Darren92
    Darren92 Well-Known Member
    2,029
    513
    Or have a stab at fitting it yourself! :p
    Theres nothing more satisfying than getting a new toy working.
    Schlaag, -Ju- and Sayam like this.
  35. Ash187
    7,505
    748
    Yes optical parking requires the front and rear sensors with the correct parking module to get it all activated... i can install this for you if you require.
    Also the S3 bumper 'upper' part is the same as the prefacelift S-line model
  36. -Ju-
    2,373
    493
    The upper part of the 8P3 S3 bumper is the same fit as the 8P2 although the pdc holes are bigger on the earlier model
  37. -Ju-
    2,373
    493
    Nice work!
    I'm in the collecting parts process for front and rear as atm I have the Audi retrofit kit.
    Can i ask how you went about the front?
    Did you drill your front bumper and did you use kufatec looms throughout
    I have the oem sensor loom for the rear and kufatec loom for the controller
  38. Darren92
    2,029
    513
    I went all out and bought a brand new S-Line front bumper with PDC and headlight washers.
    It came with sensors and front sensor loom so I only needed the sensor -> module loom and the couple of parts for the pdc button on the dash.
    I now have the switch mount and two blanks fitted so I'll take a pic later and post up.
    Oh and I needed the pdc controller also which supported 8 sensors and OPS.
  39. -Ju-
    2,373
    493
    So far i have,
    A new top part rear bumper with pdc holes
    6 sensors ( all black same as the car)
    PDC controller for 8 sensors
    Rear loom
    PDC controller loom
    1 speaker
    Dash button
    I still need,
    2 sensors to match the front grill
    4 holders for the front sensors
    Front bumper loom
    Front to rear loom
    Another speaker
    So basically most of the front.
    I am keeping an eye out for an S3 front bumper but tbh i dont mind drilling mine
    I wouldnt mind the black optics grill with pdc though
  40. Schlaag
    Schlaag Bwah
    486
    32
    Looking awesome, that's the way I want to go! is there a thread dedicated to optical parking? that lists part numbers etc? I'm pretty hands on so would want to install myself. (I've dropped you a PM Darren)
    Buying and changing bumpers is hassle so I wonder if buying the cobra retro fit 17mm hole punch that comes with their latest flush fit sensor kit would work?
    http://www.ebay.co.uk/itm/17mm-Cobr...248?pt=LH_DefaultDomain_3&hash=item3f447cffa8
    Darren92 likes this.
