Does anyone have access to the front door wiring schematics?
Sent from my SM-N910V using Tapatalk
After finding that it's going to be a few more days before my VAS-ODIS ships, I decided to re-enable the rear door modules and fiddle with the coding with VCDS. I got it on my second attempt and only had to change one digit, the 4th from the left, from a 3 to a 5.
Original coding: 004317204000048000000002
Working coding: 004517204000048000000002
I suspect that in cars with different options (or adaptations) that this same digit is the one that needs to be adjusted. If you decide to attempt yourself, just make a note of your own original coding first just in case....
Update your VCDS to the latest version, if you canI have forgotten to comment that I VCDS is on 12.12.3
Which one do you use ??
- 19 - CAN Gatway
- Select Gateway installation List
- Scroll down and activate Modules "BB - Door Rear Drv Side" and "BC - Door Rear Pass Side"
- Save
- Code Modules as needed in order to activate lights
- 19 - CAN Gatway
- Scroll down and remove modules "BB - Door Rear Drv Side" and "BC - Door Rear Pass Side"
- Save
- Run an AutoScan
- Clear DTC's
- Un-Tick display freeze frame
- Run AutoScan = Should be no errors
Could someone help me please,Hi.
I was fitted with a puddle light and warning light on the front door of A3 8V MY15.
On the 8V model - the supply is pin 16 and the earth is pin 5.
After wiring, it requires coding of both the driver's seat side and the passenger side.
Please refer to the following URL coding settings.
http://garage.jenare.com/pack-eclairage-dans-les-portieres/
Unfortunately, I do not know the wiring method of puddle light and warning light of the rear door.Please let me know someone good idea.
Good luck!
I know now which connector you mean,It looks like you worked at wrong connector. This connector is T20 connector. Find T32 connector. This T32 connector locate at the trim side of the door. And it is plugged vertically at the left side of the door controller .
That one right ?
Sent from my Nexus 6P using Tapatalk
So it is 16 live and 5 Earth,? Just to confirmOnce you'e put it into T32b hole 16 and reassembled it then close the door and then open it, the lights should now work.
Can't seem to find the wiring for rear doors
And earth?T16 connector pin 12.
And earth?
Thanks a lot !Brown wire can't remember the PIN number off hand
But there's only one brown earth in that connector.
Thanks a lot !
Sorry to bother that much, but do you happen to know the coding if necessary?Brown wire can't remember the PIN number off hand
Bit 2 needs ticking.Sorry to bother that much, but do you happen to know the coding if necessary?
Sorry I am doing it through obdeleven, can you point me in wich section I am supposed to turn them on? It shows door electric driver and passenger side but not rearsBit 2 needs ticking.
Then close and open the doors and lights will come on.
Rear BB & BC modules are the same bit that needs ticking too.
Obdeleven cannot access to the rear door module of A3 8V. You may use newest version of vag-com, VCP or ODIS.Sorry I am doing it through obdeleven, can you point me in wich section I am supposed to turn them on? It shows door electric driver and passenger side but not rears
Thank you! I would have to look somewhere around South Miami, USA to code it !Obdeleven cannot access to the rear door module of A3 8V. You may use newest version of vag-com, VCP or ODIS.
- Only possible on models with an rear door control unit, this is installed when a or more of the options are:
- Parental Electr. Press (PR-4 H 5, switch in the drivers door for rear doors)
- illuminated interior door handles are installed (PR-QQ4)
- illuminated speaker grilles are installed (PR-QQ4)
- Decor deposits (PR-5MA, 5MB, 5MD, 5MY, 5TD, 5TG, 7TM)
