Retrofit LED Rear lights A4 B5
highlanderorr Nov 25, 2010
  1. highlanderorr
    highlanderorr New Member
    10
    I have recently retrofitted a set of LED Rear lights on my A4 B5, but keep getting a bulb out error evertime I switch them on. Does anyone know how to override this.:(
  2. Broken Byzan
    13,237
    466
    you need either resistors or to disable the light checker all together.
    I went for Resistors, you will need 4 x resistors as you need one per side for the side lights and then the same for the brake lights..
    Available on Ebay for around a £5 easch
  3. highlanderorr
    10
    Thanks for that any idea what ohms and volt resistors needed???
  4. highlanderorr
    10
    Thanks for that any idea what ohms and volt resistors needed??? ​
  5. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
  6. pjw
    pjw Member Audi A4
    222
    If you can find out the rating of the resitors you could just buy them from maplins for about 10p each.
