Retrofit Cruise
rosscotdi Apr 1, 2007
  1. rosscotdi
    rosscotdi Member
    118
    Hi All,
    Has anyone done this?
    I know cruise can by fitted by non dealers using geninue Audi parts so...
    Can i do it and how much will it be to get the bits to do it myself?
    Being a Electrician i'm quite technical and i know my way around a tool box!
    I assume i'll need vag-com to enable it at the least?
    Cheers in advance
  2. marms
    marms Member
    833
    It can easily be retro fitted.
    Had mine done by a main dealer before I took delivery.
    Needs a new cruise stalk, new lower cowl and depending on what equipment you all ready have, a new steering control module.
    Once all this is in place you need to either use VAG-COM or a dealer to recode for the new feature.
    Took the fitter (ie no mechanics work for audi anymore) less than 45mins to complete.
  3. shaheed
    shaheed Member
    65
    What kind of service needs to be done to "enable" the cruise device presviously mounted?
    I don't have VAG-COM, meaning I do need to go to the dealer so that the cruise control is enabled, but I need to know exactly what kind of service is that.
    Regards.
  4. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    It needs a login code in the Engine ECU to enable it.
    You could probably find a local user with VAG-COM who could do it for you for a Beer Token or two.
  5. Boydie
    Boydie Guest
    anyone have a guide handy??
  6. Evotek
    Evotek Member
  7. Boydie
    Boydie Guest
    merci mon frere!
  8. biryets
    biryets New Member
    12
    There is someone selling the kit (including fitting) on ebay.
    judging by the price of the kits for other cars, the additional lower stearing trim increases the price for the A3 kit significantly.
    the link is
    <stores.ebay.co.uk/Hazzydayz-Ltd_Cruise-Control-Kits-VW-Audi_W0QQcolZ4QQdirZ1QQfsubZ2QQftidZ2QQtZkm>
    I'm still strugling to justify paying for it.
  9. rosscotdi
    rosscotdi Member
    118
