Retrofit Cruise Control
Nimo Feb 19, 2003
  1. Nimo
    Nimo New Member
    10
    I'm thinking about getting cruise control fitted into my S3. I did not get this as an option but I kind of wish I had as I always find myself speeding!! Has anyone had this done? Can you recommend anywhere to get this done and price?
  2. Gambba
    Gambba Active Member
    1,361
    You can do it yourself if you know someone with a VAG-COM who can enter the correct coding for you, then all you need is the stalk and an additional harness which connects into the existing chassis harness (So I'm told, by one of my colleagues who's done it on his VW). Parts can be found on Etka parts CD and priced up through Audi or maybe VAG Parts (Who may have it as a kit). http://www.vagparts.com/
    If you fancy doing it yourself and don't have access to parts info drop me a PM.
    For Audi to do it I think you're look at 250-300 GBP at a guess, across here it's 480 Euros for my local dealer to do it.
  3. scoTTy
    scoTTy Active Member
    1,962
    I'd get Amd or APR to do it (IIRC about £199)
    If your doing it yourself be very careful with the airbags etc.
  4. Gambba
    1,361
    [ QUOTE ]
    [/ QUOTE ]
    That's quite a good price for the fitting of cruise control.
    There is a method to removing the Airbag, which quite a few of my colleagues/friends have done with no problems, but if you're not particularly mechanically minded then probably the do-it-yourself route is not the best.
  5. Ken
    Ken New Member
    12
    The price depends on the model of vehicle you have.
    Earlier build cars (I think pre-2000) have cable throttle, and therefore would cost a lot more.
    The newer cars are all Drive By Wire (electronic throttle) and are easy to retrofit. In Australia, the kit for the DBW cars only costs around AUD$120, plus probably 1-2 hrs labour to do it.
    The older models are probably more trouble than it is worth.
    Ken
  6. Adam
    Adam Member
    34
    had mine done for switching my APR chip - £150+vat from Stealth Racing - took about 1.5 hours
    wouldn't do it yourself unless you are very mechanically-minded
  7. Nimo
    Nimo New Member
    10
    Thanks for your help everyone.
  8. Mo-S3
    Mo-S3 Member
    706
    Nimo... where abouts r u ??
  9. Nimo
    Nimo New Member
    10
    London
  10. tvr1
    tvr1 Member
    49
    [ QUOTE ]
    [/ QUOTE ]
    correct me if im wrong but iwas under the impression all S3 were drive by wire or were you refering to a3's,, maybe not, ive never looked at my s3 throttle, i hope it is cos i want the cruise fitted at some stage
