Retrofit Cruise Control question (Slightly different one though)
evilbane Apr 5, 2011
  1. evilbane
    evilbane Member VCDS Map User
    129
    Hi guys I have read up thoroughly and have all the kit VCDS/Cruise control stalk and lower cowling.
    I have a very early 2005 A3 2.0 TDi so realise it's a little hit and miss if my car has the control wire.
    My question is if my car does or does not have the control wire, should it be present in Pin 13 on the main steering black plug, as I know this is the pin it has to be fitted if needed?
    I'm just wanting an easier way to find out if it needs the extra wire without having to reassemble everything only to take it all apart again.
    Also what is the part number for the extra wire needed, or is it just a standard Audi repair wire?
    Cheers in advance:wub:
  2. Ads
    Ads License to drive
    8,230
    613
    PM Johnny (jb0o) the link to this thread. He's the resident cruise expert.
  3. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    Haha, cheers Ads.
    Your research has served you well mate. If there is a wire in PIN13 of the black plug that goes into the Steering ECU then you have the wire and wont need to look anywhere else.
    The wire iirc is brown/white.
  4. a8 tech back
    a8 tech back Member
    198
    if you have mfsw then the cruise lock command wire is present, only early none mfsw and new tt dont have the wire normally
    and you will recive a can fault from address 16 if missing implausible signal
  5. evilbane
    129
    Thanks buddy just what I wanted to hear, do you know what part number the extra wire is, or is it just a standard Audi repair wire?
  6. evilbane
    129
    I dont have MFSW, just the standard leather sport version :(
  7. a8 tech back
    a8 tech back Member
    198
    bummer, as already mentioned your dropping the cowling anyway so just check the pin location and keep your fingers crossed mate
  8. jb0o
    2,664
    118
    Not a normal repair wire, one end is different... I'm not 100% sure on the part number of the wire as I've always got the wire with the Cruise Kit (8P0 054 690), but on ETKA I can view the parts involved in that kit and other than the stalk there is the 'cable tie with terminal socket' - pn 1Y0 971 838, so my bet is that the wire is within the bag of cable ties. The price is £0.87 + VAT, worth a try.
  9. evilbane
    129
    I dont suppose you have a spare/unused cable from a kit you fitted i could buy from you jb0o?
    Thanks for the help as well guys, i knew there was a reason i liked this place so much:salute:
  10. mike foster
    3,967
    Think I've got one you can have mate from the kit I bought and didn't need it.
    If I can find it I'll PM you for your address.
    evilbane and a8 tech back like this.
  11. jb0o
    2,664
    118
    I don't I'm afraid mate, would have given you it for free but I used all mine during the London installs at the weekend :(
  12. jb0o
    2,664
    118
    Mike to the rescue! :)
  13. terrytrout
    terrytrout New Member
    hi
    i fitted a retro cruise to my 06 A3 and when I stripped the cowling down , I too had a simular problem. I noticed that there was already a wire in the plug (pin 13), therefore did not require the extra wiring. I just remapped the ecu to accept the cruise and everything was fine.
  14. mike foster
    3,967
    Evilbane needs one and has been sorted !!
  15. evilbane
    129
    Thanks to Mike, the guys awesome he is even going to deliver it to my house tomorrow!!!! :applaus:
  16. jb0o
    2,664
    118
    Mike is definitely a cool guy. Give him a handshake from me, haha.
  17. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,094
    581
    got 1. quick question. got my cruise retrofit parts supplied, and since my car is facelift 2009 s3 with fbmfsw do i have to conect that wire that is in the box, or just mount the new part and recode it with vcds? thanks
  18. mike foster
    3,967
    No, you won't need that wire !
    Good luck with the mod.
  19. 1animal1
    9,978
    S. let me know how you get on, was thinking of doing this but didnt know how easy hard/involving it would be
  20. S.
    2,094
    581
    Great!!
    probably will try to do it today.
  21. jb0o
    2,664
    118
    Make sure you have the most up to date VCDS. On facelift A3's to code Cruise its either Byte 6 Bit 1 or Byte 5 bit 5.
    Before last week the Byte 5, Bit 5 had no text to it but a new update has sorted this out so you should be alright!
  22. S.
    2,094
    581
    so got it done in one hour. no wires needed. just new stalk and cover. coding (couldn't do it with vcds912 so managed to do it with 10.6).
    it works great, no errors. had steering wheel and abs lights on for few seconds did lock to lock steering wheel turn and it went away.
    thanks for help!
