Retrofit cruise control on an S3
svensktoppen Jan 9, 2010
  1. svensktoppen
    svensktoppen New Member
    19
    Has anyone done this on an 8L model (1999)?
    Can get the stalks, etc., from Audi, but I was wondering what ECU programming is involved?
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i belive you need the stalk and lower panel to fit it, and just vag com coding relitively simple
  3. rossbrownlee
    rossbrownlee Ross_S4
    719
    You don't need the lower panel mate. all you need is the stalk and the looms. They can be bought off ebay as a kit from this link here which is what i used.
    If you have access to vagcom the coding is really easy. that would probably be your best/cheapest option, otherwise audi could do it for you but bet there would be a price.
  4. S3 Rav
    S3 Rav Well-Known Member
    2,824
    30
    i think awesome gti were doing a deal on these for like £100
  5. rossbrownlee
    719
    yeah awesome are doing a good price fitted but the op is in belfast, a bit far to go...
  6. chancer
    chancer Member
    114
    Don't forget the clutch switch if it is missing from yours. There is a big myth on here that it is some sort of speed sensor, but the switch is to deactivate cruise when you push the clutch, so as to avoid the inevitable over reving
  7. rossbrownlee
    719
    yeah definately! also, even if it is fitted you should check it on vagcom if you have access to it.
    Once my cruise was installed and coded it wouldn't work. turned out to be the clutch switch hadn't been properly adjusted when the pedal was replaced.
    It is easy to do. just remove the switch from the bracket, gently pull the plunger bit out (you'll hear clicks) then reinstall it and press the clutch pedal fully down. thats it adjusted.
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    ahh so thats just for us 8p owners then :p, good to know, ta
  9. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,751
    353
    I bought the kit (stalk and looms) in March, but am still to get them fitted. They're just sitting in my room. Maybe once I get the MOT/Service in a few days, I'll find time to sort it. Or maybe I'll see if Audi will do it while the car's in.
  10. rossbrownlee
    719
    No disrespect to audi mechanics as they are great at what they do and it is not their fault but... the main dealers labour rates are pretty high in comparison. It might end up costing you a bit getting it done there.
    The retrofit kit really isn't that hard to fit if you give yourself a bit of time to do it and just take it steady.
  11. MartayMcFly
    2,751
    353
    I would do it myself, apart from VAGcom, if it didn't involve removing the airbag. Not really sure I want to risk getting that wrong when I'm taking it out, or putting everything back together. I'm probably going to get some suspension work done soon (new ARBs to fit) and maybe a remap, so I can just get that garage to do the cruise at the same time... should sort of bundle the labour all into one too.
  12. svensktoppen
    19
    Thanks all,
    Got the same info from Audi the other day - new indicator stalk (different from 8P), wiring, and reprogramming.
    They did say the connector on the ECU is not always present, needs put in if not there. Has anyone had issues with this?
    Thanks for the clutch switch tip, did not realise that.
    One other problem for me - my car is LHD, not sure if the kit looms would fit? Are they hard to get made up?
    Cheers,
  13. clark#34
    clark#34 New Member
    Is it possible to fit cruise in this way to my 99 TDi sport?
  14. svensktoppen
    19
    Checked a bit more with Audi, they say they do not sell wiring for retrofitting any more. They used to, but have stopped on these older cars. Now they only sell the complete engine loom, which comes with or without cabling for cruise. So the only option is having the wiring made up.
    Awesome do a complete conversion for a very reasonable price, but can only do the whole job. They make up the loom on site when they do the conversion, hence cannot sell a "kit".
    So, that is pretty much it I guess. Will have to use the right foot a bit longer :)
  15. rossbrownlee
    719
    hi mate as i said in a previous post with the link to fleabay, the kit COMES WITH STALK AND ALL REQUIRED LOOMS.
    This is a good price for the parts and fitting is relatively easy.
    also pretty sure the kit will fit the LHD cars as the instruction manual in the kit refers to LHD cars.
  16. svensktoppen
    19
    Thanks rossbrownlee, missed your first post :)
    Have asked them if it will fit LHD, just in case, but you are right the instructions are actually for an LHD car.
  17. svensktoppen
    19
    They confirmed it fits both LHD and RHD, so thanks again :)
