Retrofit cruise control not functioning as intended
heeman10 May 27, 2010
  1. heeman10
    heeman10 Audi driver since Dec 08
    375
    Thanks to mike foster, itwasntme187 and dave_ph, I have now retrofitted cruise control to my car. Audi quoted £399....I did it myself for £95. Thanks Audi!
    The CC as a function works, but the switch doesn't work as it should, and this is something mike foster is also encountering, as described below.
    SET button does nothing.
    Pulling the CC stalk towards me does nothing, UNTIL I press up (+) or down (-), and THEN CC is activated. It cancels when I push the stalk away from me, as it should, but flicking it back towards me does not activate the RESUME function. Again, I have to push the stalk up or down.
    itwasntme187 doesn't have this issue - his functions as it should, as depicted on the switch. Anyone else having this problem?
    I'm chuffed to bits that it's installed and working, but I would prefer it to work precisely as it should. Any ideas?
  2. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    Maybe the switch installed has a problem, VCDS check and you should be able to monitor the switch actions in data blocks.
    Not sure which module but probably either Engine Management or Steering ECU.
    Paul
  3. mike foster
    3,967
    Probably unlikely that two identical switches bought in different parts of the country have the same problem.
    We also have different steering ecu numbers so it's unlikely to be that causing the problem.
    The two cars in question are both 2.0l TDI Sportback one March 2005 and the other July 2005. Both had the control wire pre-installed in the steering ecu.
    The puzzle continues !
  4. Gti Jazz Blue
    1,655
    OK didn't realise that this was two cars, it is possible that Audi had a faulty batch of switches. It would still be worth checking in VCDS to see if you can see each switch working.
    The retrofit to my March 05 2.0TDi went fine and works correctly, as there was a question mark over the Steering Ecu on mine, I did however order the newer version and install it to save taking steering wheel off again.
    Paul
  5. Ryan_Pestell
    Ryan_Pestell New Member
    29
    what do you need to do this? you have a link to the retro fit? as this is the only option that my car doesnt have and i really wanted.
    stalk, and then then upper and lower steering cowels? presuming the car is fitting for it wiring wise.
    Ryan
  6. mike foster
    3,967
    Ryan - it very much depends on the model, year, chassis no. and steering ecu version.
    As far as the cowl is concerned you just need the lower part.
    You will also need to have the steering and engine ecu's re-coded, either at Audi or by someone local to you with VCDS.
    Best bet is to call Audi with the details and they should tell you what is necessary for your car.
  7. Ash187
    7,496
    744
    Do a search on the forum for the part numbers you need to get it working, i have posted this info in about 10 different posts in the last month!
    also check your chassis number with Audi to find out what is already in your car, as you may be lucky and find that the parts you need is already in there.
    Took me a couple of hours to fit in the Cruise and MFSW in my A3, mind you it was the first time i have ever taken a steering wheel off. not a hard job really.
    I have checked with James and we have different cruise switch part numbers but mine works fine and is a july 2005 build.
  8. mike foster
    3,967
    Hi itwasntme187
    Mine is a July 2005 Sportback like yours and Dave at Stoke Audi checked the chassis no. and sent cruise stalk ref. 8P0 054 690. I think James has the same one.
    Which one do you have ?
    Mike
  9. Ash187
    7,496
    744
    Hi Mike,
    Yes Dave supplyed me the same cruise switch as yours and it works perfectly fine. James on the other hand says he has a different switch then us.
    Ash
  10. mike foster
    3,967
    Hi Ash - that just leaves the steering ecu then !
    Mine is ref :- 1K0 953 549 AF and according to ETKA requires the same retro-fit kit as ecu part no. 8P0 953 549 F that everybody seems to refer to !
    Can you remember your ecu no. ?
  11. Ash187
    7,496
    744
    I fitted 8P0 953 549 F
    not the AF version, it could be this which is causing the issues, i was advised by all to get the F version for it to work properly.
  12. mike foster
    3,967
    Or could it be the 1K0 instead of 8P0 ?
    Do you reckon the coding needs to be different somewhere ?
  13. Ash187
    7,496
    744
    i think you have the 1K0 version, as im thinking that is what i had in my car to start with. though i did see in the coding of my original unit that i could enable cruise, but since i already had bought the 8P0 ... F controller so i fitted it.
    i only coded the steering controller in one place where you can set if you have just the mfsw/with bluetooth/with voice activation/with bluetooth and voice activation.
    then I coded the engine to tell it that cruise is installed. so overall 2 changes made to enable cruise
  14. mike foster
    3,967
    Cheers mate - think I'll have to give Dave a ring and ask him if he knows of any difference/problems in coding CC in different ecu modules
    Mike
  15. Ash187
    7,496
    744
    no problem mate, anytime :)
  16. gynads
    gynads Member
    314
    I have an 07 S3, is it likely ill have to change my steering ECU? (im currently offshore so cant pop out and check!)
  17. Ryan_Pestell
    29
    ok cheers for the info guys, its a late 2004 Sportback 2.0TDI Sport
    will try and check with the stealers and see what i need and what is fitted to the car
  18. Khufu
    Khufu Well-Known Member
    5,704
    31
    best getting rev F as AF is also useless for MFSW, best not limit options.
  19. ahtcap
    ahtcap Member
    187
    22
    Same problem here.Did you manage to get to the bottom of it?
  20. Ash187
    7,496
    744
    The reason why that happens is because you have the wrong steering control module
  21. ahtcap
    ahtcap Member
    187
    22
    The one i have ends in "F" which one should i have? (2005 sportback)
  22. Ash187
    7,496
    744
    Your one starts with 1K0? You need the 8P0 version
  23. ahtcap
    ahtcap Member
    187
    22
    Not 100% certain but i think mine is 8P0,will check tommorrow (working nightshift)
