Retro fitting xenons question
maars Aug 18, 2008
  1. maars
    maars Full speed ahead
    576
    Is it true that the standard and bi xenon lights are switchable from lhd to rhd spec on the units themselves? Or is my ebay seller telling porkies?!
  2. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    If you are talking about 8P A3 ones then no it's not true. 100% porkies mate.
    To be more accurate Bi-xenons can be put in tourist mode with VCDS/Vag-com. All this does is lower the beam slightly, it doesn't make it a flat beam as is often thought.
    I think older xenons can be changed to a flat beam by moving a manual switch. I may be wrong though.
  3. kaz219
    kaz219 Active Member
    1,808
    I'm unsure but if this is the case, but if you can do LHD to RHD you must be able to do RHD to LHD.
    So would a member have seen the switch to do this while fiddling with there xenon headlights???????
    I had a set on my Golf with projector lenses and they were switchable...there was a metal hanger bit that you pulled and pushed...
  4. NHN
    29,523
    1,766
    Staz nearly right mate on 1st & also correct on 2nd thing, older cars had the metal lever that did as you say & actually the newer cars that have halogen/standard xenon on dipped beam have these still I believe(I'll check mine to confirm this), bi-xenon have these aswell I think, but what Staz means is the Bi-xenon Plus/Adaptive headlights can be amended in vag as these are the only ones that have the left/right motors inside to be able to do electronically, bi-xenon & bi-xenon plus are different from eachother purely cause the latter can turn left & right with the steering of the car basically also known in europe as with Curve(round corners) as this is what I'm currently got to do as mod to my car, just need the lights now.
    So my existing xenons will be for sale soon & kufatec do the conversion kit for them so plug n play for swap from halogens, wish my mod was this easy.
  5. mitch78
    mitch78 Active Member
    2,350
    :thumbsup:
  6. maars
    576
    Thanks for the feedback. Sounds like the xenons might be switchable, which is good.
    Part nos are 8P0941003S & 8P0941004S.
    Can you PM me and let me know how much you are looking for for your xenons? Thanks!
  7. royjk
    royjk Member
    167
    I have questioned my local Audi dealer on this who claim there is no manual switch on new A3's for xenon adaptive lights so it seems as it has to be done via Vag. They will do it for a fee of £50.
  8. h5djr
    9,447
    1,762
    My dealer says the same. When I went on holiday to Germany and Switzerland recently I changed mine to 'tourist' mode using VAG.COM.
  9. maars
    576
    But is 'tourist mode' the same as changing from RHD to LHD or vica versa?
  10. Staz
    6,206
    67
    No bi-xenons need to be adjusted with vag.com also but they can't change to LHD mode. They only lower the beam.
    Adaptives I forgot about and didn't know the answer anyway!
    No. As I said in my first post all it does is lower the beam. It does not change the beam pattern whatsoever.
  11. maars
    576
    so what about normal not bi xenons?
  12. NHN
    29,523
    1,766
    check your lights for the lever mate or you can lower them manually with screwdriver, thats what audi tech guy told me, easiest solution overall he said, you could check with vag if standard xenons have even if it says only plus & adaptive in rosstech wiki, infact if I can later I'll check on mine.
  13. Staz
    6,206
    67
    I don't know to be honest. I doubt it though as I know with most companies you can't do it. I know this because I live in Germany and everyone has to buy continental lights when they import a car there. Myself included.
    Do you mean me? I know mine do not have a manual lever. 100%. I had to swap my lights for continentals when I took the car to Germany. And I know I can set tourist mode with vag-com as I have done it.
    You can of course lower the beam manually on any lights by adjusting their height as you would to make normal adjustments. But this isn't what we're talking about here. And either way the beam pattern is not correct so they won't be UK road legal.
    Maars can you send the link to the ebay auction? I can't use ETKA on this computer so I don't know what those part numbers refer to. You can PM it if you're worried about someone on here bidding against you.
  14. NHN
    29,523
    1,766
    I'll let you know when done, lol, you need 1-2 looms from kufatec, new headlight range control module as with adaptive it changes part & of course headlights with also new control modules in base, I've got all bar the lights so waiting for some to come up so I can start doing the mod., only thing worries me are DRL's as some speculation over them when doing the lights upgrades even from lower lights to basic bixenon that Mattandrew is gonna do, so trial & error but can be done with time & some knowledge
  15. maars
    576
    Nigel - how much are you after for your existing xenons? PM me with more details please...
  16. maars
    576
    Can someone with ETKA let me know the part nos for LHD and RHD single and bi-xenon headlights pretty please.
    Thank you!
  17. NHN
    29,523
    1,766
    8P0941029N & 030N are standard xenon for pre-facelift
    8P0941029AA & 030AA are the bixenon for pre-facelift
    8P0941029AB & 030AB are the adaptive cornering one for pre-facelift
    best to ask if you find a pair if they are what you need mate as some might have older letters at end as superseded with above or even above might be replaced aswell.
  18. maars
    576
    By pre-facelift do you mean pre 2009 A3 8P cars?
    ebay.de ones appear to be 8P0 941 003/4M or 003/4S - no good I guess?[FONT=Arial, Helvetica, sans-serif][/FONT]
  19. NHN
    29,523
    1,766
    yes pre 09, M & S are right hand traffic & no good as they are setup for beam on other sides & cant be adjusted to our side only lowers beam, you could use the beam adjusters stuck on but looks *****, just waiting for my italian bird to decide on when moving to italy then I have to swap mine to german anyway which is why I said mine are gonna be for sale
