Can any one help with What's needed to retro fit cruse control. as I'm breaking a4 b4 avant and that's one of the items I'm not sure what parts I need to remove to sell with every thing included so it's ready to fit ?
Cruise stalk, control module and lower cover are needed, although original cover can be used and modified.
You won't know if you need the control module until you remove the old one and check the part number, although most b6's without cruise fitted at factory will need the module.
Cost is around £30 for the stalk, £100 for the module.
Then you need the control module coded in, airbag reset and abs reset as well.
