retro fitted cruise, can't code wheel in vagcom
ldormon May 20, 2007
  1. ldormon
    ldormon New Member
    10
    Hello all
    Just followed the instruction at audiretrofit.co.uk, the hardware install has gone very well but the vagcom bit is not so good [​IMG]
    So I go to code the steering wheel and first up its thinks its a multifuction one which it isn't (it already has the code 04352) so I try and replace the code, and nothing happens, it just goes back to 04352 Do I need to login to change it.
    Also I take it I'm getting all the abs warnings because I need to finish the rest of the instructions?
    And my remote key fob no longer works, do I need to re-encode that as well.
    Cheers for any help
    Lee
    Ps I'm running 704 but thru parallels on a mac, hope that isn't screwing it?
  2. Sebastian
    Sebastian Member
    286
    Post a complete Auto-Scan please so we are able to check all related parts, codes, codings etc.
  3. ldormon
    ldormon New Member
    10
    OK, I've played with it a bit more, I think I've the right steering wheel encoding. The howto I followed didn't say you had to login to the abs to do the coding, so it not coming up with the mega abs errors anymore. But what is this "System Function Test Activated" I seem to have set in the abs?
    Many thanks for any help.
    Lee
    VAG-COM Version: Release 704.1
    Data version: 20070422
    Monday,21,May,2007,22:40:39:10720
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E03A143513 Mileage: 138640km/86146miles
    Address 01: Engine Labels: 059-907-401-AKE.LBL
    Part No: 8E0 907 401 D
    Component: 2.5L V6 TDI G200SG 0009
    Coding: 02015
    Shop #: WSC 00205
    Part No: 00005059
    Component: 130 106LC150_1.V79492758287
    WAUZZZ8E03A143513 AUZ6Z0B0159565
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 8E0-614-517.LBL
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 1726
    Coding: 04255
    Shop #: WSC 00000
    1 Fault Found:
    01486 - System Function Test Activated
    35-00 - -
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Part No: 8E0 820 043 K
    Component: A4 Klimaautomat 1016
    Coding: 00000
    Shop #: WSC 63351
    1 Fault Found:
    00710 - Defroster Flap Positioning Motor (V107)
    41-10 - Blocked or No Voltage - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0203
    Coding: 00001
    Shop #: WSC 63351
    1 Fault Found:
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.LBL
    Part No: 8E0 959 655 B
    Component: Airbag 8.4EP 2000
    Coding: 0010602
    Shop #: WSC 63351
    Address 16: Steering wheel Labels: 8E0-953-549.LBL
    Part No: 8E0 953 549 P
    Component: Lenksáulenmodul 0711
    Coding: 01022
    Shop #: WSC 00000
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
    Part No: 8E0 920 950 J
    Component: KOMBI+WEGFAHRS. RB4 D35
    Coding: 01400
    Shop #: WSC 00205
    Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
    Part No: 8E0 959 433 BC
    Component: Komfortgerát T3B 1110
    Coding: 07115
    Shop #: WSC 63351
    Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0002
    Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0002
    Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0002
    Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0002
    6 Faults Found:
    01616 - Signal Wire to Interior Monitor
    49-10 - No Communications - Intermittent
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    00956 - Key 2
    35-10 - - - Intermittent
    01562 - Right Rear Door
    61-10 - Won't De-Safe - Intermittent
    Address 56: Radio Labels: 8E0-035-1xx-56.LBL
    Part No: 8E0 035 195 C
    Component: symphony II NP2 0151
    Coding: 01201
    Shop #: WSC 00481
    End --------------------------------------------------------------------------------------------------
  4. Sebastian
    Sebastian Member
    286
  5. ldormon
    ldormon New Member
    10
    Cheers it all works a treat now :)
    Many thanks
    Think I may need to find a dreaded windows laptop, vagcom is a little flaky under parallels on the mac
