Retro-fit Sat Nav RNS-E (from 'concerto') - where can this be done in South-East?
Simon S4 Feb 20, 2011
  1. Simon S4
    Simon S4 Member
    55
    I am thinking of retrofitting my 2004 S4 with Sat Nav (the RNS-E system), from its current 'concerto' single CD radio. I undertstand that as it is going from a small slot to a bigger one it takes a bit more time and the conversion is more expensive - but where in the South-East can this be done? I came across a place in Bradford but this would mean a day trip for me...any tips?
    Simon
    :s4addict:
  2. hades-
    9,481
    646
    get the parts needed and diy
    its very easy
  3. Simon S4
    Simon S4 Member
    55
    Thanks bez101 - even the conversion from one 'single' concerto into the 'double' slot needed for the sat nav? ...I am not very much into DIY...?!?
  4. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,994
    217
    I've done two single to double dinn conversions now although i didn't fit RNSE'S ( i used kenwood media systems ). It's not that bad to do providing you have all the correct parts, i actually used new double dinn consoles on both as they are slightly different to single dinn ones and all original parts were kept to re-install on sale of the cars, i have a pdf on this if you require it.
  5. Cabbyfan
    Cabbyfan Active Member
    840
    34
    I did a single to double in my last B6 saloon, took 6 hours approx but as long as you have a decent selection of socket set kinda stuff its actually pretty easy. Then the RNS-E just slots in, mine was cool even though I say so myself.
  6. hartey
    hartey Member
    207
    Can i have a pdf please!!
  7. AU01 A4
    AU01 A4 Member
    211
    Me Too, Please :friends:
  8. mattyboyc
    1,994
    217
    Please pm me your email and i will forward it on
  9. carlos19664
    carlos19664 Member
    60
    Hi Im new to the site and Im looking to do the same thing with my B6 Cabriolet I have a link to somewhere in the southeast that can retro fit, if you want it let me know if I can post it on here and I will send it
  10. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    60
    HazzyDayz (VWcruise.com) are based near St Albans, but they will travel anywhere around London for next to nothing if you'd prefer to have it fitted at your house.... that said, they're not cheap these days :(
    It's a viable DIY job, but takes a few hours, general jist of it is: glove box off, old stereo out, aircon buttons out, single din cage out, double din cage in, cut half an inch off each side of the aircon buttons so that it fits lower in the console, fit those back in, then slide the RNS-E into the double DIN cage.... there's little bit more to it (especially if you want to mount the satnav antenae behind the dials and also the VAGcom recode to get the directions on the centre dials, but you could probably do most of it at home and then persuade somebody on here to help you out with the VAGCom stuff if you turn up with a few cold beers...
  11. carlos19664
    carlos19664 Member
    60
    You must have read my mind? thats the link I was going to give him thanks
  12. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
    I had mine fitted from a forum member, I sourced all the parts from pjmspeedy such as the double din cage, RNS-E. It took a few hours to complete but was worth it.
  13. kev1000
    kev1000 Member
    209
    Hi, I'm looking to do the same and I'm wondering do the install kits on eBay hold in the aircon aswell as the double din stereo?
    Or do I need to get a genuine Audi double din cage?
    Also do I need to move the console surround( the piece that goes down around the gearstick and back around the armrest)?
    I would greatly appreciate any help or tips as I'm a bit nervous about taking this job on.
    Cheers,
    Kevin.
  14. mattyboyc
    1,994
    217
    Pm me your email address and i'll send you a pdf on how to do it, i've done two now and there not that bad to do
  15. kev1000
    kev1000 Member
    209
    pm sent:thumbsup::thumbsup:
