Retro fit RNS-E from single din to double din
Kevin Edwards Jul 12, 2008
  1. Kevin Edwards
    Kevin Edwards mr kevin edwards
    :sos:I have successfullly fitted to my 2006 Audi A3 ( RNS-E) sat nav from single din to double din unit but having troble obtaining the new switches E.g hazard warning, Air Bag etc , I have been to the Audi garage but only managed to obtain the switch cover,they were not very helpful at all seemed like hard work , I would appriciate any help part numbers or any place I may be able to contact and sort What switches I need
  2. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    Here's some info I posted in the S3SB Rear Lights thread on the part numbers for the facelift switches:
    NigelHobden was telling me last night that he has been able to order the new switches and a coin drawer for the facelift. You may want to wait until he gets his sorted before ordering anything as you might aswell get the latest parts since they'll be the same price(-ish) anyway.
    If you would prefer to go with the original pre-facelift gear let me know and I'll dig out the part numbers.
  3. Kevin Edwards
    thanks for for the info I have ben in contact with Nigel Hobden through e- bay he was selling is old switches and i made the assumption he had just done the same as me, He as been very helpful and he gave me this web site to try so i can finish the job off. Do y0ou know the part number for ther coin draw
  4. Kevin Edwards
    I have never used one of these web sites before but thanks for all your help
    Kevin
  5. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    when you say new switches, do you mean the ones for the double din cage or the facelift switches of the new A3
  6. mdre83
    mdre83 Member
    634
    Kevin, got any pics of your car mate.
    Welcome tothe forum too.
  7. Kevin Edwards
    The ones for the double din cage as mine seen to be at the angle when i have fitted the switch cover
  8. Khufu
    Khufu Well-Known Member
    5,704
    31
    there are two versions now of the smaller switches. The older ones are smaller versions of the single din switches, the new facelift versions are more rounded.
    This is the face lift type :
    These are the older style :
  9. Kevin Edwards
    The switches are the newer type ??
  10. Khufu
    5,704
    31
    The top picture is the new style of switches that will be coming out on the facelift car, I guess it must be available in Germany already? (image was taken from ebay where the guy was selling the whole double din cage/switches and aircon unit)
    The lower picture is of the switches of the current model. When I said small switches what I meant is that they are smaller than single din switches which won't let the cover fit over them except the hazard but as you say, its at the wrong angle.
  11. mdre83
    mdre83 Member
    634
    Kevin, if you don't mind me asking, how much did it cost you to do the single din to RNS-E double from start to finish?
  12. benw123
    benw123 Moderator
    1,863
    Kevin, also check out http://www.navplus.us. It's a website dedicated to all things RNS-E, with dozens of links to online fitting guides, part numbers and loads of other information. I couldn't have completed my retrofit without their help - in fact, while my RNS-E was still hanging out of the dashboard in the car, I was rushing in to the house to check their site every now and then!
