Retro-Fit Puddle Lights
I'mRonBurgundy? May 30, 2008
  1. I'mRonBurgundy?
    I'mRonBurgundy? Lets make that kitten purr...
    554
    Seems like a nice fairly cheap mod in theory, but does anyone know if it is a simple plug 'n' play jobbie along the lines of the ambient light pack?
  2. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    Looks like you need to buy the lights 6Y0 947 411 - seems to be a set of 2. This is to replace the reflector in the edge of the door.
    There is a flat contact housing which plugs into it 893 971 632.
    The puddle lights are: 8D0 947 415 (same no for front and rear) and the connector is 893 971 632 also.
    Presumably you then just need to take power from whereever the door open signal is sent and bob's your uncle. You'll probably also need to cut a hole in the bottom of the door panel for the light to clip into.
  3. I'mRonBurgundy?
    554
    Can someone do me a favor and post a pic of said puddle lights? On and off if poss?
    Just want to compare to my door to get the general idea.
    Ta very much.
  4. MarcQuinlivan
    2,539
    This is the ETKA diagram for them (circled)
    And this is a picture I found on one of the Audi web pages. A bit small, but you get the gist:
