Retro cruise control re-coding
l5tuy Mar 12, 2012
  1. l5tuy
    l5tuy Member
    65
    Hello,
    I have spent a bit of time searching the forum with no luck so hopefully someone here can help.
    I am looking to retrofit cruise control to my 58 reg tdi but was wondering if I need to get Audi to code it in or can I do it with VCDS? I haven't bought VCDS yet but if it's possible to retro cruise control with it will be a good excuse to buy it I guess.
    Thanks for your help.
    l 5tuy
  2. hades-
    9,481
    646
    you can do it with VCDS
  3. xs2man
    xs2man Member
    792
    Are you sure? When I was looking into it, I had come to the conclusion that the B8 couldn't be coded with VCDS, and would require Audi to do this.
    Would love to be proved wrong though.
  4. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    Don't take this the wrong way but you are proven ;-)
    Cruise Control Retrofitting (8T) - Ross-Tech Wiki
    I would suggest you are thinking of SVM. When Audi carry out a change or retrofit they use SVM (Software Version Management) to do the coding and also update the Audi central computer with the details for the car.
  5. hades-
    9,481
    646
    i saw my mate do his b8 so knew it could be done
  6. l5tuy
    l5tuy Member
    65
    Perfect, thanks very much for your help guys. Just found a steering assembly for £40 (used of course) so once I buy a VCDS dongle the cost will equal the £300 Audi wanted, however I will have VCDS :icon_thumright:.
    l 5tuy
  7. VRStu
    1,073
    Do you mean a stalk assembly? You may be unfortunate and need a Steering Controller / Slip Ring.
  8. l5tuy
    l5tuy Member
    65
    Slip ring with the stalks attached is what I meant bud. Think it may be off an estate though as it has rear wash wipe selection (I think) I'm presuming this function just won't work (I have a saloon) on my car. Do you foresee any probs with using an avant slip ring on a saloon?
    l 5tuy
  9. VRStu
    1,073
    I think you should be ok mate. Just modify the coding so it's not looking for a rear wiper.
    Did you get the lower trim cowling?
  10. l5tuy
    l5tuy Member
    65
    No, didn't get the cowling but hopefully Audi won't charge to much for a new one.
    Thanks for you're help bud, us Stu's stick together :icon_thumright:
  11. VRStu
    1,073
    No problem. Pop back and let us know how it goes.
    Not sure if it's still the case but on the A3 and older A4's the markings for the enlarged opening were in the cowling so you could dremmel it out if that way inclined.
  12. hades-
    9,481
    646
    dremmel is the best not seen an b8 one ill have a look tmoro when im at the unit
    save a few ££ if the markings are there
