Resetting Tiptronic Memory Settings!
meatychi Dec 11, 2006
  1. meatychi
    meatychi Member
    261
    I have gained access to VAG.com and I need to know how to reset the memory on my autobox.
    It doesnt seem to want to change out of 3rd gear for some reason!
    Does anyone know where I can obtain this info from?
  2. Uwe@Ross-Tech
    Uwe@Ross-Tech Member
    130
    If it's stuck in 3rd gear all the time, you've got problems that aren't going to go away by "resetting the memory". Do this to start with:
    Select -> 02-Auto Trans -> Fault Codes -> Copy Codes.
    Assuming your transmission controller talks at all, this will stuff all pertinent data into the Windows Clipboard. From there, you can paste it here, or into an intermediate Notepad file if the PC you're using to scan with doesn't have internet access. Then post the results here.
    -Uwe-
  3. meatychi
    meatychi Member
    261
    Thanks for the reply!
    it doesnt get stuck all the time. It seems to have troubles differentiating when to change. If you drive like and old man it revs past 3000 before changing up - if you put your foot down, it slmost redlines before changing, even if you ease off the accelerator.
    I'll borrow my friends vag again and grab those outputs you were refferring to!
    Phil
  4. meatychi
    meatychi Member
    261
    My friend tells me that he ran your suggested code output yesterday, I am going to run it again today but here is the results from yesterday anyway:
    Monday, 11 December 2006, 11:06:01
    VAG-COM Version: Release 409.1-S
    Control Module Part Number: 4B0 907 401 K2
    Component and/or Version: 2.5l/4VT EDC 0000AG D50
    Software Coding: 01004
    Work Shop Code: WSC 00012
    2 Faults Found:
    01117 - Generator Terminal DF Load Signal
    27-00 - Implausible Signal
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-00 - -
