resetting the service reminder?
Rob W8 Feb 12, 2006
  1. Rob W8
    Rob W8 Member
    953
    Hi, I got my car serviced at a local garage a while ago, but now the service reminder is flashing up saying 1000miles to service. Is this something I can turn off? Other question is will it be a problem when it passes the deadline?
  2. Rob W8
    Rob W8 Member
    953
    Anyone? Its a bit annoying now whenever I turn the car on.
  3. S3Steve
    S3Steve Active Member
    1,621
    20
    Someone with Vag Com would be able to turn it off for you.
  4. Rob W8
    Rob W8 Member
    953
    Nice one!
  5. rickparmar
    rickparmar Active Member
    2,323
    14
    there is a way of doing it using the milege reset or the clock one, ill have to look it up on here, and ill get back to you
  6. Rob W8
    Rob W8 Member
    953
    cheers
  7. HTC
    HTC Active Member
    3,428
    9
    The procedure is explained in vehicle handbook.
  8. evotista
    evotista Member
    118
    Rob,
    If your on AVS servicing schedule then the only way of resetting it AND remaining on AVS schedule is through VAG-COM or official dealers VAS5051. You can use the manual technique thro using the insturment pod buttons, but this then takes you off AVS on to standard fixed servicing ie, every year or 10000 miles.
  9. Rob W8
    Rob W8 Member
    953
    Hi, I am servicing it every 10000miles like a caring audi owner should.
    Cheers for the info guys, will sort it myself.
    Rob
