Resetting check engine light and ln1
VuDuStetson Nov 9, 2003
  1. VuDuStetson
    VuDuStetson New Member
    9
    how did u reset the check engine light? also, right where the trip milage is, how do u reset the ln1 indicator?
    thanks
  2. moschino
    moschino Member
    252
    Hi,
    Below is copy of the instructions on how to reset the oil service light from a post in the Diesel section. It might be worth a try!
    Press and hold the right button. (odometer reset)
    now switch on the ignition
    (oil lamp will not flash, but on at all times)
    press the right button again
    (insp is now displayed)
    pull left button. (clock set)
    (------ are now displayed)
    Pull left button again
    This works on my A4 tdi (110bhp) but should work on all.
    As far as the 'Check Engine' light, you could try disconnecting the battery for 20 mins, this worked on my Impreza. Perhaps someone can confirm this before you try it, you might need to enter the code for the stereo after? Make sure you have your keys in your pocket before doing this incase the central locking activates!
    Otherwise, try a garage that has a diag tool or someone that has vag.com software and the diag cable.
    Hope this helps,
    Jim.
  3. VuDuStetson
    9
    for some reason it doesn't work, i can't press in my left button, the clock button, i have a 97 A4.
  4. qA4Blake
    qA4Blake New Member
    23
    i had the same problem with mine. it should be in your owners man. You have to pull the left(clock) button out and then push the left button in. you might have had it backwards. but follow the inst. above.
  5. Siena
    Siena Active Member
    2,626
    Only works on cars built halfway through '97 and later, when it became mandatory, that the vehicle owner / operator MUST be able to re-set the service indicator, without having to visit a dealer, and without specialist software.
  6. Markey
    Markey Active Member
    2,175
    Can you do anything else to reset the oil light VAG com etc?
    I have a R reg 1.8T
  7. Siena
    Siena Active Member
    2,626
    On your car, you don't need VAG-com to reset the service / oil warning, just do it manually.
  8. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    it tells you in teh owners manual, but I followed teh instructions and still couldn;t get it to work!!
  9. Markey
    2,175
    What as said above ?
