resetting airbag light
KevM3 Sep 8, 2010
  1. KevM3
    KevM3 Member
    102
    had the front seats out today on myw reg tqs for valetinig ,now the airbag lights on ,disconnected the battery but still on , how do you rest it
  2. manzi
    manzi Member
    64
    been told you need computer hooking up to get rid of it, something to do with error code being flagged up on ECU, needs clearing with either fault code reader or comp with VAGCOM or some jazz.
  3. aragorn
    18,299
    804
    Dont piss around with a code scanner, they're useless, get yourself a vagcom lead.
    You can either buy the real deal for £200ish, or buy a clone cable from ebay for a tenner and run the software in free mode.
  4. griswold
    griswold Member
    350
    As your in cardiff i may be able to help depending where you are
    I'm out and about tomorrow so i may be able to meet up and remove it for you?
    pm me
  5. evilscotsman
    evilscotsman Space Cowboy
    1,350
    14
    if you need to remove the seats again, disconnect the battery first and wait 15 mins before pulling the connectors under the seats, they go to the srs (seatbelt restrain system) which is part of the airbag unit and will always trigger the error light.
  6. aragorn
    18,299
    804
    The car will have side airbags, which are mounted in the seats, if its newer than ~97.
