[Request] need my vcds adaptation login code !!
princeofthepc Mar 12, 2012
  1. princeofthepc
    princeofthepc New Member
    Chassis Type: 1U - Skoda Octavia I
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
    VIN: TMBHK11U432744486 Mileage: 153710km/95510miles
    Address 01: Engine Labels: 06A-906-019-AEH.lbl
    Part No: 06A 906 019 CQ
    Component: 1.6l 2V/R4 SIMOS AT3317
    Coding: 00033
    Shop #: WSC 31480
    Address 02: Auto Trans Labels: 01M-927-733.lbl
    Part No: 01M 927 733 HS
    Component: AG4 Getriebe 01M 4469
    Coding: 00011
    Shop #: WSC 00000
  2. NHN
    29,333
    1,717
    Genuine vcds cable?
  3. princeofthepc
    of course :D
  4. princeofthepc
    VCDS Version: Release 11.11.2
    Data version: 20120126
    Friday,02,March,2012,14:06:58:32661
    Chassis Type: 1U
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 4F 52 56
    62 72
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CJA) Labels: 06A-906-019-AEH.lbl
    Part No SW: 06A 906 019 CQ HW: 03L 907 309 AA
    Revision: 12H14--- Serial number:
    Coding: 0050078
    Shop #: WSC 00066 000 00000
    VCID: 73EED60A12AE09B
    1 Fault Found:
    005488 - Engine Start Blocked by Immobilizer
    P1570 - 000 - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 20635 km
    Time Indication: 0
    Date: 2006.14.21
    Time: 06:40:25
    Freeze Frame:
    RPM: 966 /min
    Speed: 0.0 km/h
    Voltage: 11.93 V
    Absolute Pres.: 1020.0 mbar
    Absolute Pres.: 1009.8 mbar
    Temperature: 0.9°C
    Temperature: 10.8°C
    Readiness: 0 0 0 0 0
    Part No SW: 01M 927 733 HS
    Revision: 05351113 Serial number: 00001106011922
    Coding: 0000020
    Shop #: WSC 02069 000 90108
    VCID: 1736C29A269685B
    No fault code found.
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 114B600C492300FB880B06EA92210042B70000
    VCID: 7BFEFE2AFAFE41B
    Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
    Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
    Component: VWKESSYPQ35GP 085 0802
    Revision: 00085000 Serial number: 0149839023
    Coding: 030C0C
    ASAM Dataset: EV_KESSY_PQ35GP A01018
    ROD: EV_KESSY_PQ35GP_VW36.rod
    VCID: 336E160A9A2E49B
    Address 08: Auto HVAC (J301) Labels: None
    Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
    Component: AC Manuell H19 0304
    Revision: 00001015
    Coding: 0000001002
    Shop #: WSC 00066 000 00119
    ASAM Dataset: EV_ACManueBHBVW36X A01010
    ROD: EV_ACManueBHBVW36X_VW36.rod
    VCID: 800409C61B18A23
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 084 G HW: 5K0 937 084 G
    Component: BCM PQ35 B 011 0048
    Revision: BG011001
    Coding: 6F380E3F802F3EC4008800C1600008C441000086575D05F0E4 802020A040
    Shop #: WSC 00066 123 12345
    VCID: 36682F1E815C5C3
    Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer 25071 26 0512
    Coding: 009795
    4 Faults Found:
    01496 - Bulb for Fog-Lamps; Left (L22)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 52
    Mileage: 21049 km
    Time Indication: 0
    Date: 2006.14.24
    Time: 13:41:16
    Freeze Frame:
    Term 15 On
    Voltage: 12.85 V
    ON
    ON
    OFF
    OFF
    OFF
    01500 - Bulb for Fog-Lamps; Right (L23)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 52
    Mileage: 21049 km
    Time Indication: 0
    Date: 2006.14.24
    Time: 13:41:16
    Freeze Frame:
    Term 15 On
    Voltage: 12.85 V
    ON
    ON
    OFF
    OFF
    OFF
    02745 - Bulb for Daytime Running Light; Left
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 52
    Mileage: 21049 km
    Time Indication: 0
    Date: 2006.14.24
    Time: 13:43:53
    Freeze Frame:
    Term 15 On
    Voltage: 12.30 V
    ON
    ON
    OFF
    OFF
    OFF
    02746 - Bulb for Daytime Running Light; Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 52
    Mileage: 21049 km
    Time Indication: 0
    Date: 2006.14.24
    Time: 13:43:53
    Freeze Frame:
    Term 15 On
    Voltage: 12.30 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
    Component: AirbagVW10G 013 0724
    Serial number: 003GVRA03U8%
    Coding: 00003133
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: 3F864A3AA6669DB
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
    Component: BF-Gewichtss. 007 0001
    Serial number: ---0000R--00060X2T00
    Crash sensor for side airbag; driver side:
    Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME583A115EZZZ/
    Crash sensor for side airbag; passenger side:
    Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME4A0E4360ZZZZ
    Crash sensor for side airbag; rear driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3511HSME72721128ZZZB
    Crash sensor for side airbag; rear passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3521HSME40111228ZZZ1
    Crash sensor for front airbag; driver side:
    Component: F.Sens.Fahr --- ----
    Serial number: 35527SME2E575827ZZZQ
    Crash sensor for front airbag; passenger side:
    Component: F.Sens.Beif --- ----
    Serial number: 35627SME516C4827ZZZM
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
    Component: LENKS.MODUL 009 0136
    Revision: FF010039 Serial number: 20101122200261
    Coding: 100A140000
    Shop #: WSC 00066 000 00184
    ASAM Dataset: EV_SMLSNGVOLWS A01004
    ROD: EV_SMLSNGVOLWS_VW36.rod
    VCID: 7DFAF032ECEA4FB
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H09 0013
    Coding: 820000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 972 C HW: 5K0 920 972 C
    Component: KOMBI H32 0310
    Revision: X0032006 Serial number:
    Coding: 270F01
    ASAM Dataset: EV_KombiUDSMM9RM10 A04305
    ROD: EV_KombiUDSMM9RM10_VW36.rod
    VCID: 306419066B38723
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 K HW: 1K0 907 951
    Component: J533 Gateway H40 1620
    Revision: H40 Serial number: 17071101290901
    Coding: 352002
    VCID: 387421268B48AA3
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 920 972 C
    Component: IMMO H32 0310
    Coding: 000007
    ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
    ROD: EV_ImmoUDSMM9RM10_VW36.rod
    VCID: EAD04B6E0D64483
    Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
    Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
    Component: ELV-PQ35 H20 0230
    Revision: 00000000 Serial number: 11000122409004
    Coding: 4900000000000000
    Shop #: WSC 00066 790 50316
    ASAM Dataset: EV_ELVMarquMPVW36X A01001
    ROD: EV_ELVMarquMPVW36X.rod
    VCID: 2E58077E710C643
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Component: SG EXT.PLAYER H13 0240
    Revision: A1001003 Serial number: 7660196729
    Coding: 020000
    VCID: 2952F46240E203B
    Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
    Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
    Component: RNS315-NAR H32 0265
    Serial number: VWZAZ2L8458703
    Coding: 04000401040007000000100A
    Shop #: WSC 01383 790 50316
    ASAM Dataset: EV_RNS315NARV2UDS A01004
    ROD: EV_RNS315NARV2UDS_VW36.rod
    VCID: 234EE64A2ACED9B
    Data medium:
    Subsystem 1 - Part No: 3AA 919 866 B
    Component: NAR_V2 0002
    1 Fault Found:
    1048669 - Tuner for Satelite Radio
    B11CF 53 [009] - Deactivated
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 188
    Mileage: 13329 km
    Date: 2004.14.07
    Time: 07:39:59
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 701 HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0501
    Revision: 13110009 Serial number: 0002511717
    Coding: 0004B5
    ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
    ROD: EV_TSGFPQ35BRFVW46X.rod
    VCID: DBBE1EAAD23E21B
    Slave Driver:
    Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D
    Component: J388__TSG-HL 006 1509
    Serial number: 00000005882027
    Coding: 000490
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 70 3201
    Revision: 00H20000
    VCID: 346C151657204E3
    Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 1K0 907 951
    Component: EZE_2 H40 1620
    Coding: 050B0500
    VCID: EFE65A7A3E86ADB
    Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
    Component: J245EE20SKB13 H02 0220
    Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
    Component: J394EE20SKB13 H02 0220
    Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 702 HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0501
    Revision: 15110009 Serial number: 0002502663
    Coding: 0004B4
    ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
    ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
    VCID: DCBC1DB6D730263
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D
    Component: J389__TSG-HR 006 1509
    Serial number: 00000005774256
    Coding: 000490
    Address 72: Door, Rear Right
    Cannot be reached
    End ---------------------------------------------------------------------
  5. princeofthepc
    and sorry for getting on your nerve :S
  6. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    773
    57
    Hmmmm
    Same user name ... ?
  7. NHN
    29,333
    1,717
    Good find, glad my instincts wernt failing me.
  8. vfr800
    773
    57
    :icon_thumright:
    I'm a bit of a n00b when it comes to VCDS so excuse my ignorance. Do I need to post a scan/prove ownership of my car to get a 'login code' so I can login in to my instrument cluster to be able to brick it?
    I did have a quick look at the FAQ but didn't see anything about how to request / acquire a login code.
    BTW - I have a paid for / registered VCDS-Lite license (and cheap arse cable from ebay).
    Liam
  9. NHN
    29,333
    1,717
    Login code for what though as I dont know what he or you require, if you mean skc, I cant give you that as its stored on the car anyway.
