Replacing Tyres Question
ScottishA4B9 Nov 25, 2013
  1. ScottishA4B9
    ScottishA4B9 Well-Known Member Team Daytona Audi A4 S-line owners group TDi saloon
    3,008
    766
    Hi All,
    I'm replacing my tyres on my front wheel drive A4. Is it best to have the tyres with the most tread on the front?
  2. DrSasso
    DrSasso Active Member
    207
    32
    Statement retracted as been proven wrong :p
    ignore/wrong:
    (given that it's a FWD I would say yes :) want the most grip for traction and turning so deffo the front would have preferance in my opinion :))
    correct: back tyres put onto the front and new tyres put onto the back.
    ScottishA4B9 and Audi Dynamik like this.
  3. SI-W85
    SI-W85 Well-Known Member
    1,321
    351
    I've got a set of pirelli p zero rosso tyres only done genuine less than 400 miles 235/35zr19 y rated, only want £250 for the pair they cost that each so a bargain for someone who wants some good tyres...
  4. hades-
    9,481
    646
    so you have a set or a pair ?
  5. SI-W85
    1,321
    351
    Oh sorry I have a pair of 235 the others are 295s my mistake
  6. ianv5
    ianv5 Active Member TeamMisano Team V6 Audi S4 quattro Audi Avant Owner Group
    546
    197
    43
    Wrong answer!
    New tyres need to go on the back!
    Just Google it.
    You need more grip on the back incase the front does go the back will hopefully keep you on the road.
    kanecullen89 and SI-W85 like this.
  7. Zafi
    Zafi Well-Known Member
    1,265
    315
    Not the case with modern cars like the A4. ESP takes care of any grip problems at the rear. So fit your new tyres to the front for maximum traction.
  8. ianv5
    546
    197
    43
    Most tyre/car forums sites suggest new on the rear, can't find many posts suggesting you fit new to the front?
    However my car being a Quattro I will probably have to change all 4 at once!
  9. Audi Dynamik
    Audi Dynamik Well-Known Member
    2,218
    308
    I found with my Quattro that all the tyres worn out evenly ian :thumbsup:
    Just as long as you don't scrub the front tyres while stationary like the wife has a habit of doing :mad:
  10. kanecullen89
    kanecullen89 Active Member
    569
    160
    43
    I've always been told that best tyres go on the rear. Theory being that understeer is a lot more easy to control than oversteer. If your fronts lose grip and you're not going to fast for the road conditions you can normally regain control quite easily. If you lose grip on the rear it's a lot harder to control and you'll probably end up in a ditch. ESP can only help you if your tyres can actually grip. With low grip conditions the 'power' of the systems abilities are limited
  11. enoliver
    enoliver Member
    93
    When I did a Traffic Patrol Course with the police, we had some input from the Transport Research Laboratory, at Thatcham.
    They showed us video footage of exactly this problem. When you brake heavily, the weight of the car is pushed forward, over the front wheels. This makes the back of the car lighter, and the front heavier. If you have less tread at the back, it is more likely to let go, particularly in the wet, when aquaplaning is more prevalent. It is therefore always better to have the best to the back, regardless of whether it is front or rear wheel drive. I would stress that this has been proven, and isn't just an opinion.
  12. DrSasso
    207
    32
    well I got schooled xD I retract my previous statement....maybe I remembered it wrong.
  13. ScottishA4B9
    3,008
    766
    Well I have 2 tyres that are 8mm and 2 that are just over 7mm, so it makes no odds really. I will put the 8mm on the front as they wear quicker.
  14. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,612
    2,533
    Regardless of the amount of tread the most important thing is to buy quality tyres with grip . Fit ditchfinders with 8mm of tread all round you will be worse off than somebody with part worn decent make tyres. All tyres are not equal.
    When I bouight a car a few years ago it had nearly new Accelera tyres on the front. They were truly awful in the wet regardless of the fact they were nearly new. I had wheelspin when accelerating from roundabouts and junctions without a great amount of throttle and prolific understeer on roundabouts. I bought some part worn Continentals to replace them after about 2 weeks of owning the car.
    The car was so much better dry and wet, especially in the wet.
    To have fitted those tyres on the back would have been mad, they shouldn't have been on the car in the first place.
    Karl.
  15. ScottishA4B9
    3,008
    766
    I've got Continental Contact Sport 5P's to put on all round.
