Replacing the rubber grommit around the roof aeriel?
jediknight Oct 4, 2007
  1. jediknight
    jediknight Member
    835
    Finally got round to detailing my own car today... upon closer inspection of the roof the rubber around where the aeriel base sits on the roof is really perrishing (rubber on the aeriel is split aswell)
    anyone know if its easy to replace without stripping the interior headlining out??
    and can i just buy the rubber grommit?
    thanks
  2. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    You can get the Aerial kit from Vagparts haven't got a clue how to fit it though. Looking to do the same at some point
  3. jpda4
    jpda4 Member
    126
    21
    i done mine a while ago, same problem.....
    all you need to remove is the rear courtesy light, once thats dropped you should be able to see the nut holding the ariel base in place, carefull not to loose the wire when disconnecting it could disappear behind headlining.....(i put a tie wrap on mine just incase i lost the end)....... hope this helps
    im sure someone will give a fuller explantion later
  4. jediknight
    jediknight Member
    835
    excellent.. will do it at the weekend then
    ta
  5. vanilla_ice
    vanilla_ice Active Member
    704
    26
    I also need to cvhange mine soon as its has a split in the grommet. I ordered a new complete base through vagparts today as apparently Audi have redesigned the base to improve it's design (read this: http://www.audi-sport.net/vb/showthread.php?t=19565&highlight=ariel).
    Might not be true but for £36 it includes a new grommet anyway (allegedly), so I will be replacing the whole thing.
    Hope this helps,
    ICE
  6. vanilla_ice
    704
    26
    How do you safely go about removing the courtesy light?
    Thanks,
    ICE
  7. danotto
    danotto VAG HUNTER
    1,090
    so to hijack but jedi how did you manage to write off your blue s3 looks totalled
  8. jediknight
    jediknight Member
    835
    that was a long time ago... american guy pulled out without looking. i hit him at 60-70mph span into opposite lane into a van and hit back across into my lane
  9. danotto
    danotto VAG HUNTER
    1,090
    fudgin hell,looks well bad,hope you wasnt hurt bloody yanks i bet he was in wrong lane.lol
  10. jojo
    28,886
    3,539
    Brings back bad memories huh?
  11. cjhill
    cjhill hmmmmm interesting.
    335
    regarding the light, you just pull it out, it has clips along the edges.
  12. Pat
    Pat Member
    515
    I need to replace my ariel soon... I would like a small shark fin type.. can these be fitted???
  13. sprout99
    sprout99 Member
    373
    i did mine a while back - its fiddly and a few skinned knuckles
    the hardest part was undoing the aerial connector to get the bloody thing of
    sat in boot with my head torch on
  14. vanilla_ice
    704
    26
    Could some kind person please list all required tools and sizes to change the base/grommit please?
    I want to make sure I have everything in place before starting the job.
    Thanks in advance,
    ICE
  15. jesters3
    1,516
    Has anyone managed to do this or have the part number for the full aerial kit?
  16. dot32
    dot32 Member
    I've just fitted one of those, from the newer audis. It fits fine but it's not connected, but still using the old whip aerial which is tucked in the roof lining behind the rear courtesy light.
    I'd show you a pic but the posting rules say I can't post attachments...
    I think the aerial cost about £25 from the dealers.
  17. vanilla_ice
    704
    26
    I have "a" part number for a full ariel kit, but I'm not 100% sure it is the right part (yet).
    I had a look at the base of my current ariel through the roof lining and it seem to look different, but then I read somewhere that Audi had redesigned the base, so maybe I'm worrying over nothing.
    I'll try and post the part number of what vagparts sent me tonight.
    Has anyone got a diagram for the assembly of the ariel and it's installation?
    Cheers,
    ICE
  18. dot32
    dot32 Member
    Mate, If yours is like mine - 2001 on, then the nut is on the outside. unscrew the whippy bit, then prise the black cone shaped base cover off, obviously take care of the paintwork, the base cover is 2-3 mm thick and is just clipped on.
    When you undo the nut, the base, should fall through the whole in the roof.
    Hope this helps!
    cheers
    j.
  19. dot32
    dot32 Member
    p.s does anyone know how I can upload pics?
    taa
  20. s3_tny
    s3_tny Member
    91
    Upload pics to a photobucket account and then copy and paste the url for it
    but make sure you put these symbles before [​IMG] the address
    info is in the bottom let of the pages under posting rules
    and just make sure you preview page first to make sure pic shows properly
    hope this helps :thumbsup:
    or anyone correct me or explain it easier pls
  21. macdoug
    macdoug Member
    52
    It is obvioulsy badly designed if all these Audi ariels are packing in after just 5/6 years!
    Does the Audi replacment pack include the "Whippy bit"? The whole ariel including the base and the seal is cracking on mine so i am as well to replace the lot at once.
    Also, i thought the S3 ariel was at a different angle to the Golf ariel so it could be that the VAG part is slightly different.
    Iain
  22. jonS3
    jonS3 Member
    719
    mine is fine, but why on earth did audi not realise the aerial hits the rear spoiler when the boot is fully open.....?! fools
  23. bpascua
    bpascua Member
    81
    Chaps,
    I'm confused, the vag parts bit from the photo looks like it just hugs the rim of the aerial base like a big washer, the aerial base doesnt actaully sit on it like a mat is that correct? cant be esle surely we wouldnt need to remove the dam thing to fit it.
    Brian
  24. vanilla_ice
    704
    26
    4B9 051 505
    This was for a non Sat Nav head unit. It is the ariel base complete with new ariel.
    It has a female spade connector on a red and black wire (for power?) and a short (10cm) legth of ariel cable that I hope will connect on to the exisiting ariel cable.
    Hope this helps!!
    ICE
  25. bouncer--daz
    bouncer--daz A dog is for life....not just for friday nights!
    537
    Me being a lazy ***** used the car wash and forgot to remove the aerial... which was then broke off so this is a job Im guna have to do very soon. Has anyone got any photos of the process?
