Replacing side light bulb on light switch
Ginger Prince Sep 1, 2012
  1. Ginger Prince
    Ginger Prince Member
    189
    Hello all,
    On the way to work this morning I’ve noticed on the light switch that the side light isn’t illuminated meaning the bulb must have gone behind dash/console.
    Has anyone ever replaced one of these, if so, how to you remove the console for the light switch and is it a pig of a job? It will do my head in so I’m going to have a go once I know what I’m doing....
  2. mike foster
    3,967
    On my 2006 MY the switch comes out by just turning the knob anti-clockwise which unlocks it and then it just pulls out.
    Not sure you can replace just the bulb (probably LED). A new switch is about £70 from Audi but they often come up on ebay.
  3. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    I'm pretty sure on my MY2009 you turn the dial to 12 oclock, push in and turn to the right and then pull out.
  4. Ginger Prince
    189
    Thanks pal. I've got a 57 plate (2008) so I'll have to keep my eyes peeled for a switch on eBay & hope mine "just pulls out...."
    Mike
  5. mike foster
    3,967
    Sincere apologies - had a 'senior' moment !
    You are absolutely correct - push in and turn clockwise and pull switch out
  6. RobRS
    RobRS Member Audi RS3
    I've just sent you a PM regarding a replacement Light Switch...
  7. quinnii
    quinnii Active Member
    328
    94
    Iv had my light switch in pieces today so I can post up a pic of the light you would need to replace?
    It's a doddle to replace the smd if your any good with a soldering iron.
  8. Ginger Prince
    189
    Rob - Ive send you a PM back cheers
    Quinni - I don't have a soldering iron but I appreciate your response and someone else may benefit from your pics and advice if you put them up?
  9. quinnii
    328
    94
    Il pop them up tomorrow when i get hold of my camera.
    Let me know if you dont get it sorted, i think iv got an old light switch lying about somewhere from a 2007 car
  10. Ginger Prince
    189
    Cheers Quinnii, if you've got one (I've got a 2008 S3) then i may need it please....
  11. quinnii
    328
    94
    Is it a facelift or pre facelift?
  12. Ginger Prince
    189
    Pre-face lift mate
  13. NHN
    29,417
    1,740
    Unusual fault as never known that to happen, so when you actually put switch to sidelights it doesnt light up?
    Do you have coming home button & auto lights?
  14. Ginger Prince
    189
    I mean when the lights are on and the dash lights up the lights behind the icon for sidelights isn't illuminated, main beam is but sidelights not.
  15. Ginger Prince
    189
  16. NHN
    29,417
    1,740
    Stupid question, but have you actually checked visually to see if the sidelights are lighting up ok?
  17. quinnii
    328
    94
    It's a green smd that's there, it's slightly bigger than the other smd's aswell.
    Il pop my pics up that I took yesterday when I get home
  18. Ginger Prince
    189
    Whats an smd & yeah, the exterior lights aren't an issue, its the bulb behind the switch which isn't illuminating as per the pic.
  19. quinnii
    328
    94
    Firstly some info on SMD's:
    What is SMD (Surface Mounted Diode) ?,5050, 3528, 0603, 1210
    Here's some pics for you:
    In this pic you can see the location of the SMD's compared to the light switch housing:
    In this pic iv highlighted the four solder points for the SMD, there only small but would only take a minute to do. SMD's are penny's compared to a new light switch unit:
    I can spec an SMD replacement if you want and link it for you.
    This might help anybody who's thinking of an SMD upgrade for a different colour.
    Hope it helps
  20. NHN
    29,417
    1,740
    He needs ascertain its the light source at fault tbh before changing for new & also are the sidelights actually working which I did ask further up with no reply, as someone could of messed with coding, whose to know on the forum, but of course it could be its not lit for that very reason, 1 to discount anyway.
  21. quinnii
    328
    94
    I agree, just from his post i assumed everything was working as per usual just the bulb wasn't lighting up.
  22. Ginger Prince
    189
    Correct, I did reply "exterior lights are working."
    Thanks guys
  23. Ginger Prince
    189
    I've managed to get a switch off 1 of the lads on here so hopefully it will be sorted shortly....
  24. PH1L
    PH1L Gievf Buckets
    3,851
    40
    sohmm i see a new project sommming on, smd upgrade ftw
  25. quinnii
    328
    94
    Iv just swapped some of the SMD's over from another unit just to make sure it's possible, incase anybody ever needs to do this. Il post some results when I get home and get it plugged in!
  26. amar06fbr
    amar06fbr Vorsprung Durch Technik
    1,055
    68
    iv already done a smd upgrade ;)
  27. PH1L
    PH1L Gievf Buckets
    3,851
    40
    well brother dont hold out pm me the info ;)
  28. NHN
    29,417
    1,740
    Yeah sorry missed that post, then has to be either wiring which doubtful atm or the led/pcb is faulty, I would stick some power across the led even from multimeter to see if it lights up.
