replacing rear lights on sportback
vw754 Sep 12, 2010
  1. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    If i replace rear lights on sportback with ones off a 59 plate..led ones,what exactly do i need to get them working apart from vag-com,do i need wiring etc,etc?
  2. navnayyar
    navnayyar Member
    756
    you'l need a control module also
  3. vw754
    2,345
    58
    is that all? where is this located exactly and does it matter if its off a car 3 years newer than mine? is the rest plug and play?
  4. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    You don't need a control module.
    All you need is the lights, vagcom and either a loom from kufatec or a rewire by yourself.
  5. NHN
    29,417
    1,740
    Scottie is spot on, no need for module, just rewire or use a loom, if not comfortable with either then feel free to PM me as I have a few of these to do for people now rewiring
  6. c_w
    c_w Well-Known Member
    1,163
    87
    What coding is required in VAGCOM for the taillight update?
  7. Stampie
    Stampie Member
    105
    I would like to ask this question also - What coding is required for the update?
  8. audicruiser
    audicruiser Audi Heaven
    1,865
    Its been covered before, but the coding tells the car not to show the bulbs as tail lights but to show the LED bar, plus the coding changes from one bulb each side for brake lights to two.
  9. Stampie
    Stampie Member
    105
    Done loads of searches but none actually explain what coding needs to be changed in Vagcom.
    Got lights - Looms ready to fit, but don't wanna fit them until I know what coding changes to make?
  10. audicruiser
    1,865
  11. Stampie
    Stampie Member
    105
