Replacing Puddle Light Bulb
NCRAW Sep 10, 2011
  1. NCRAW
    NCRAW Member
    230
    Hi All,
    I got the last bit of my LED upgrade to go which is replacing the puddle lights with the LED panels i got from Trups. I managed to open the cover but the problem is that I got no wire length to work with!! i tried to pull but im getting no slack. Has anyone else had the same issue?
  2. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    Yep, I had this. I took the door card off instead. Only takes 5 min each side.
  3. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3
    5,196
    145
  4. NCRAW
    NCRAW Member
    230
    It amazes how vag can complicate things!! By door card u mean the door interior panel?
  5. paddy
    5,196
    145
    Yes as per the instructions above :)
  6. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,050
    754
    make sure you remember to disconnect the lamp from the wire before fidling with the screwdriver in there as the fuse may pop.
  7. NCRAW
    NCRAW Member
    230
    Ok next question. Does anyone know how power is cut off to the lights when the door is closed. On other cars there is the little rubber covered spring on the body which is pressed by the door frame. I'm thinking if I cut the power then I can work on it without removing it.
  8. paddy
    5,196
    145
    It will not be simple ..like a fridge :), the computer will cut the power as it knows when the door is shut via the latch/central locking, hence the door open display in the DIS etc.
    I dont see your problem here ?? Its 5 mins to remove the door card and lay it on the kitchen table. All the wiring and lights etc are fitted to the card and the card attaches to the system with one multi block connector.
  9. DeckedS3
    DeckedS3 Well-Known Member
    867
    295
    I managed to do this without having to remove the door card. Just remove the screw/bot at the bottom of the door (could have been 2) and pull corner away where the speaker is. this should give you enough room to work with.
  10. NCRAW
    NCRAW Member
    230
    Sweet. Thanks guys. Il give the one corner pull a go first then if no go then it's the door card removal. Bloody audi service, they ripped the door card off without undoing that bottom screw when replacing the window regulator so that screw is just for cosmetic purposes only. Not that it does much after the door is closed.
  11. NCRAW
    NCRAW Member
    230
    PS. Sweet write up on door removal. Well done. Also seems like everyone who had their card removed managed to damage the screw bit at the bottom.
  12. NHN
    29,341
    1,719
    Yeap as per decked, should be simple to do with card still on the door tbh.
  13. NCRAW
    NCRAW Member
    230
    The Decked way it is then :D I'll give it a go tomorrow. Really looking forward to finishing this project. While at it, one interesting thing I have with the foot well LEDs is that when I close the door and the lights dim off then I turn the ignition to ON (not engine start) and the needles finish the sweep, the footwell LEDs do two strobes then turn off. Happens again if door is closed and they are already off and u put ignition to on only this time its 3 strobes!! dont know why cause apart from that all LEDs are performing perfectly. Its pretty cool "feature" to be honest :) makes the car feel "high tech".
  14. Usmxn
    Usmxn Active Member
    176
    Did you manage to do it the decked way this? Having the same issue myself and dont fancy taking the whole door card off
  15. s11nny
    s11nny Member
    88
    the way I changed mine was to unscrew the screw, and unclip the door card just from the bottom, I then put bulbs in and put the light back in, whilst the door card was unclipped I could fit my hands in the card and clip the wire into the light holder,
  16. Usmxn
    Usmxn Active Member
    176
    Thanks I'll give this a go and hopefully it'll work out as I currently have no puddle light on one side lol
