Replacing OEM head unit to a newer unit
spannah May 21, 2008
  1. spannah
    spannah Member
    238
    Guys,
    Looking at my OEM head unit and the new one, the OEM looks wider in size therefore the hole must be bigger. What do i do with regards to putting the new one in, as there will be a gap.
    Can anyone advise?
    A3 8L 1.8T 1996
  2. AndyMac
    9,832
    45
    What new one are you talking about?
    A new Audi one (which won't work as it'll be CANBUS controlled) or an aftermarket unit.
    If you're going aftermarket then you'll need a fascia adapter to fill the gaps either side, an aerial antenna adapter to power the beesting aerial amp and the rear amp adapter to feed the rear amp & sub from the rear RCA's
  3. spannah
    spannah Member
    238
    Sorry i will be changing my standard head unit to a Sony one.
    Where can i purchase the facia blocks and the Bose adapter from?
    What kind of prices will i be looking at?
  4. DBXdarkangel
    DBXdarkangel Member
    162
  5. AndyMac
    9,832
    45
  6. DBXdarkangel
    DBXdarkangel Member
    162
  7. naefeart
    naefeart Bonkers
    164
    29
    Apollogies for the hijack, but Andy are those the same requirements for the B5 A4?
    Have an aftermarket Sony headunit in my wardrobe, but don't want to mess about removing the rear speakers or running new cables.
    N
  8. AndyMac
    9,832
    45
    The B5 A4 just has a rear amp (no sub, unless Bose).
    You'd still need the antenna amp & fascia adapters and either an RCA input adapter to feed the rear amp or new speaker cable to bypass the crappy rear amp (which is bolted to the passenger side rear speaker.
  9. S3_Pricey
    S3_Pricey Member
    302
    just got a quick question. i have changed the HU in my A3 but did not use an ariel adaptor or a rear amp adaptor. I was just wondering if installing such items would get rid of the buzzing that is pretty much constant through the rear speakers? also where mite i get a rear amp adaptor? cheers in advance...:thumbsup:
  10. AndyMac
    9,832
    45
    If you don't have the adapter then how have you got the rears/sub rigged up at the moment?
    The adapter allows you to plug standard RCA's into the non standard mini ISO connector that Audi use to feed the rear/sub amp. So without it the rears won't work at all, so you must be using something already.
