replacing n75 with mbc 1.8t agu
GeoA3 Aug 20, 2012
  1. GeoA3
    GeoA3 Member
    85
  2. <tuffty/>
    21,689
    4,121
    Run it in parallel to cap boost else you will loose part throttle drivability
  3. GeoA3
    GeoA3 Member
    85
    do i replace this small part with the 3 ways with the n75?
    this the diagram the comes with the kit
  4. aragorn
    18,544
    865
    no, the N75 says put, do it EXACTLY like the diagram shown above.
  5. GeoA3
    GeoA3 Member
    85
    but my mbc is two parts not like the one in the picture?!
  6. <tuffty/>
    21,689
    4,121
    Not sure what you said there...
    I am not familiar with that type of bleed valve but from the picture I would assume you use the part with the screw bit on top and hook it up as per the picture above...
    I doubt its a particularly accurate one so may take a bit of tweaking to get right (Forge UNOs is the one I would normally use) but you will need a couple of T pieces too... the supplied 'diverter T' might work as one of them but again, not something I have used so couldn't say if that part is any good..
  7. aragorn
    18,544
    865
    looks like a bleed valve, not an MBC.
  8. <tuffty/>
    21,689
    4,121
  9. GeoA3
    GeoA3 Member
    85
  10. <tuffty/>
    21,689
    4,121
