Replacing haldex earth question!?!?
S3featesV9 Feb 5, 2012
  1. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    Just started to replace the earth strap from haldex to body, just wondering...the bolt that holds the earth into the diff housing. Once removed will oil come out? As it looks like its one of the many bolts that holds the outer casing on?
    Thanks in advance peeps
  2. S3featesV9
    1,032
    12
    Anyone? :((
  3. Dani_B19
    9,336
    391
    Mate just try it, if oil starts coming out just tighten it back up lol.
    Danman1 likes this.
  4. S3 Sly
    S3 Sly Member
    122
    Is not just a bolt around the drive shaft flange? I very much doubt and oil will come out, and even if it did it can only be a tiny bit as you are only whipping the bolt out and then putting it back in are you not.
    Don't worry nothing will happen :)
  5. S3featesV9
    1,032
    12
    All done now anyway dude cheers though. Nah nothing came out, apart from a bit a **** that fell in my eye. Then twa**ed my head on exhaust clamp. Haha.
  6. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Ah mate there was so much **** that fell in my eyes when I was doing this and when I replaced the haldex controller! It must of cost me about an hour just cleaning my eyes!
  7. Dani_B19
    9,336
    391
    Where you'd get the new strap from? May do mine for piece of mind.
  8. S3featesV9
    1,032
    12
    Halfords buddy £4.99. 22cm one
  9. Dani_B19
    9,336
    391
    So just a universal one then, mint.
    Guessing your old one was knackered then?
  10. <tuffty/>
    21,579
    4,051
    I bought the insulated version... has gold plated connectors and similar price (although I did buy one that was probaly too long...)
  11. S3featesV9
    1,032
    12
    Yeah mine was snapped in half at the body end. Rest of it was really brittle too tbh.
  12. S3featesV9
    1,032
    12
    One I brought was perfect length. Don't think that really matters though. Long as it doesn't sag and rub on rear driveshaft
  13. superkarl
    superkarl MAN OF STEEL
    9,554
    2,453
    thanks for this, this will be helpful!
    :icon_thumright:
  14. Gops
    3,198
    666
    Does the prefacelift have one then? Didn't see one when I went under..
  15. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Yep, done that too. Bloody painful given my lack of hair on top! Anyway, good thread, I'll add this to my list of jobs for when the sun comes out again (assuming it still exists).
  16. <tuffty/>
    21,579
    4,051
    If it doesn't it should have... consider it an upgrade :)
  17. Gops
    3,198
    666
    Adding it to the list tuffty :D
  18. Dani_B19
    9,336
    391
    Id just like to readdress this guys, where is the haldex strap located, dirvers or passengers? My s3's a prefacelift and i cant seem to see any strap but i know the 4wd works fine. So what does the strap do if the prefacelift s3's didnt have it, why do the facelift s3's need it?
  19. <tuffty/>
    21,579
    4,051
    Passenger... a decent earth is a good thing... and some prefacelifts had them IIRC... pretty sure I have seen them fitted... no doubt Audi deemed it necessary as a fix to some issue or other...
  20. Dani_B19
    9,336
    391
    Ok cheers mate, ill double check but can never seem to find it.
  21. ceS3r
    ceS3r Member
    95
    9
    Hey everyone. I'm having a problem with my haldex. S3 2003 Bam engine.
    When I log on VagCom 22-AWD it shows brake light switch 00526. Don't know if this is the actual fault.
    Just to be sure, I will check the earth strap but I just want to know, where it is located?
