Replacing front indicator bulbs
MrG A4 Mar 28, 2009
  1. MrG A4
    MrG A4 New Member
    27
    I need to replace the front nearside indicator bulb of my A4 (51plate), it doesn't seems as simple as with most cars. I'm guessing you need to slide out the headlight unit (or whatever it is called). I've worked out that the two screws at the top that need to come out, but there is something holding it in place at the bottom - any advice?
    :confused:
  2. James88
    James88 Member
    44
    if you look down between the gaps behind the headlight unit, theres another 2 more screws underneath , dont take it right off just loosen it then you be able to remove the headlight
  3. quattrojames
    14,050
    577
    Taking the lights out is pretty easy really. You just need to have a long enough Torx driver to get the lower screws loose. This guide should help:
  4. henry74
    henry74 Member
    115
    James - do you get some commission/royalties every time you put those headlight removal diagrams in a post?!? :whistle2: Only joking mate - if it wasn't for guys like you lots of people would struggle with what should be a simple job like changing bulbs! By the way (to hijack this thread a tadge) what would LED sidelight bulbs look like with standard main bulbs - cack or no? :think:
  5. quattrojames
    14,050
    577
    Lol it's the only useful diagram I have and I like to get my moneys worth out of it! :ninja:
    Dunno if it would look cack, but not sure it would look great, while you are fitting the LED's you might just as well fit some HID's ...... :undwech:
  6. MrG A4
    MrG A4 New Member
    27
    Thanks for the instructions - worked a treat!
