Replacing engine parts...
Jonesy Sep 24, 2006
  1. Jonesy
    Jonesy Member
    570
    Hi, just wondering what do you guys recommend replacing from the engine once the cars done over 80k, I have a new flywheel, cambelt, clutch, dv, airfilter. Anything else, I think i might need a new exhaust as its quite boomy at around 3k revs for some reason, maybe it has a hole?
    Also how long do the turbos last? and what other belts and parts are there to change?
    Thanks dudes
    Allan
  2. madvw
    madvw Active Member
    2,489
    waterpump? shocks?
  3. Jonesy
    Jonesy Member
    570
    cool anything else, are these parts cheap and faily easy to fit yourself?
  4. madvw
    madvw Active Member
    2,489
    unfortunately the waterpump is usually done at the same time as the cambelt. You may as well get the cambelt, tensioners and waterpump done all as one, as it's mostly labour...
  5. Jonesy
    Jonesy Member
    570
    cambelt was done before i got car, its going on on tuesday to have some work done, sort out esp light on dash, bleed brakes and fit new pads. Plus i wanna get whatever else needs doing at the same time.
