replacing bulb in centre brake light.......is it straight forward
codrock May 30, 2012
  1. codrock
    codrock Member
    50
    ive just realised my centre brake light isn't working what are they like for replacing??
    Should it have shown up as a fault when ignition is turned on??
  2. mike foster
    3,967
    I would have thought it should show a fault !
  3. codrock
    codrock Member
    50
    no-one changed one before??
  4. mike foster
    3,967
    Just remembered the high level brake light is LED and therefore is most unlikely to stop working altogether.
    Much more likely that the connector or some part of the wiring has come loose/been damaged somehow.
    I think you can remove the rear portion of the headlining to get at it. Check if there is voltage at the connector - if not then it's the wiring somewhere.
  5. bluequattro
    bluequattro Member
    411
    the plastic trim on the inside of the tailgate must be removed to gain access to high level light, as mike has said its led in design, and if all electrical connections are ok, the unit will need replaced etc, hth
    cal
