replacement sump; original or pattern-part?
jimmp Jun 16, 2011
  1. jimmp
    jimmp Member
    194
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Pattern parts ones are fine IMO. I have one sat at home which I must get on and fit.
    Go with the link, it looks fine.
  3. jimmp
    jimmp Member
    194
    Really?
    did you source yours from the same place?
    Would you replace the 20 bolts round the edge at the same time?
  4. Jordan1.8t
    Jordan1.8t Member
    201
  5. jimmp
    jimmp Member
    194
    flashy stuff!
    £130 also!
    The webbed sides look cool!
    Did you replace all the bolts??
  6. 666markyboy
    666markyboy Well-Known Member
    1,200
    49
    i don't think you need to replace the bolts... i certainly didn't when i cleaned out the sump and checked the pickup pipe, and it's been fine ever since... just make sure you use a good quality sealant... i used Hylomar Blue when i did mine as i had some left over from another job
  7. jimmp
    jimmp Member
    194
    ok Thanks for that...
    I'll probably start by cleaning out the bolts a couple times in advance...
    Got the oil and the filter now. So just to recap;
    no-one here is aware of any horrifying problems where they try to refit non-original sumps and the things don't match??
    (although as Welly says; it'll be fine)
  8. Jordan1.8t
    Jordan1.8t Member
    201
    Dont think so mate. Mine fitted perfectly. I would invest in a can of brake cleaner and a piece of 1500grit+ sandpaper.
    Makes cleaning the area of which the contact seal is going to be made a damn sight easier. Just take your time when fitting the new one. Make sure everything is clean. To make the best possible chance of sealing :).
    I done mine 1st time and not a drip/leak anywhere!
  9. jimmp
    jimmp Member
    194
    thanks for your help...
    JimP
