replacement stereo
joe_echo Sep 15, 2013
  1. joe_echo
    joe_echo Member
    67
    Ive just started having the dreaded volume issue with the concert radio in my 2000 A3 Tdi 8l, its either full or off. I'm now looking to replace it with an aftermarket model but I don't want it looking like a teenagers wet dream.
    Something that blends nicely with the audi dash and ideally has red lighting to match the current backlights, ipod connectivity and bluetooth would be a bonus.
    Any suggestions?
    Thanks in advance
  2. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    I rate alpine headunits mate expensive but worth it
  3. bi_a_op
    bi_a_op New Member
    I've got the 80PRS and you can change it's lighting in both keys and display to about 20 different colours including red. This headunit is very high end and comes with a full 3-way active built-in DSP.
  4. joe_echo
    joe_echo Member
    67
    I should have said I don't really want to spend more than £130.
  5. <tuffty/>
    20,847
    3,687
  6. kkk
    kkk Member
    109
    do you have a bose system? if you do you will need an adapter and be prepare for not quite as good sound quality, thats what iv found with mine.
  7. A3-Lee
    938
    226
    43
    Mines bose and with my alpine headunit and 12 inch sub sounds the tits tbh mate
  8. bi_a_op
    bi_a_op New Member
    In my experience and according to what I've read it doesn't matter what you buy. With known brands you usually get exactly what you pay for, at least that's a good rule of thumb in Norway for beginners (I'm not implying anything). If you have reqs like red lightning, then I'd look at Pioneer only because a lot of them offer colored lightning.
  9. kkk
    kkk Member
    109
    What adapter do you use mate, I have the ct53 au04 adaptor and got poping and crackling and allsorts. May just be my setup :/
  10. joe_echo
    joe_echo Member
    67
    Mines just the standard system, so no bose.
    I did find this though JVC KD-R841BT. What else wouldu need to replace the system?
