Replacement keys
Meller Mar 18, 2013
  1. Meller
    Meller New Member
    23
    I have 2009 model b8 sline. I've misplaced my spare key somewhere in house and paranoid either myself or mrs will lock key in boot etc. anyone know how much a replacement is? I take it audi would have to programme?
  2. hollows wife
    hollows wife Well-Known Member
    1,404
    165
    you also need to buy the key from audi . dont make the mistake and buy a second hand ebay key it will not work !
    audi will program it . expect around the £200 mark.
  3. NHN
    29,601
    1,782
    Yeah as above, just use audi for peace of mind.
  4. Meller
    Meller New Member
    23
    Thanks for replies! **** £200 I better try and find them keys!
  5. a43.0v6tdi
    a43.0v6tdi Dave
    37
    Hi folks
    I'm in a similar situation, I just bought a 3.0 tdi b8, I only got one key with it, is there definitely no way around this? Surely with all the trickery that can be done with vcds etc (excuse my ignorance in this respect as I don't know much about what can be done or with which software) don't fancy paying €350 to Audi if I can avoid!
    Many thanks for the help
  6. JG51 AUD
    JG51 AUD Well-Known Member Team Glacier TFSI Owners Group Team V6 Gold Supporter Audi S5 quattro Black Edition Supercharged
    2,675
    1,554
    Give @udi A3 a pm, he may be able to help.
    @udi A3 likes this.
  7. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    VCDS alone will never make a key. It is also limited to programming only keys precoded or previously programmed to your car.
    I have sent a pm requesting the info I need to price you a replacement key.
    HTH
    Tom
  8. Rodders.
    Rodders. Active Member
    183
    I have one proper key and a plastic emergency one. I guess I should have two proper keys and one plastic one?
  9. a43.0v6tdi
    a43.0v6tdi Dave
    37
    @udi A3 pm'd thanks
    @Rodders
    From what I understand you should have two key fobs and a plastic one
  10. Rodders.
    183
    Bah. One shory then for me.
  11. mancdan
    mancdan Active Member
    498
    51
    @udi A3, can you provide a price for a replacement key? I also only have one key and the plastic master key in the glove box. I have 2009 B8 A4 Avant.
  12. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    6,206
    2,861
    Take the plastic master key out of the glovebox !!!! . That key will start and drive the car, If somebody gets in the car they can drive it away.
    Karl.
    Kalashnikov and mancdan like this.
  13. mancdan
    498
    51
    Thanks Karl, I have just read the same thing in another thread. I didn't even think of it in that way, I have just been out to my car to remove and store safely in my house.
  14. desertstorm
    6,206
    2,861
    It makes sense as well apart from the security issue of leaving a key in the car you don't have a spare. So if you were to lose your key somehow somewhere the only key you have would probably be locked in the car.
    There are probably thiousands of Audi's around with the spare keys in the glovebox, and the wrong people know this is the case.
  15. boarderianb
    boarderianb New Member
    Audi a3 could you give me a price for a second key also have one and empty plastic shaped key in glove box bought car last week with only one key 2009 a4 sline
  16. Anthony566
    Anthony566 Active Member
    732
    111
    43
    I did find this but I assume this doe not work on a B8 ??
    http://www.audizine.com/forum/showthread.php/428047-How-to-program-your-Audi-flip-key-fob
    "I have done a ton of searching and found how to accurately program a key fob on the forums. The problem with all the directions that I had found was that once I programmed one key fob, the others would erase. None of the directions showed all the steps to program more than one key correctly without losing the others (which most people will have). This DIY has the correct programing procedure no matter how many fobs you have.
    For some reason if you pull your battery or you change the battery in your fob you might be finding a situation where you need to do this programming.
    There are two kinds of programming. If you have remotes that have been programmed to the car previously the steps are easy. There are longer steps if the keys are new and those are the secondary ones.
    Steps to reprogram keys to a car they are already linked to:
    1. Press and hold the unlock key on a remote
    2. Insert key in ignition and turn to on (while still holding unlock)
    3. Hold unlock while in the on position for 2 seconds
    4. Turn key to off, remove from ignition and release button.
    Do this for each remote. Relink to seat positions (press and hold mem position #, then unlock button for 2 seconds and release both) and done.
    To program new remotes on a car never linked to previously:
    1. Take a key (valet key works best, put it into the ignition and turn the key to the "on" position, so the dashboard lights come on.
    2. Roll down the driver's side window (not required, but a good idea in case there's a problem).
    3. Exit the car and close the door.
    4. With a second key, physically lock the doors by turning the key clockwise (don't use a remote).
    5. Take the first remote to be programmed, press the unlock button. The lights will flash once.
    6. Wait 10 seconds and press the unlock button. The doors should unlock. That first transmitter is now programmed.
    ***If you have only one key skip to step 16. Otherwise continue to step 7.***
    7. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
    8. Press the unlock button two times with a one second interval in between, the lights will flash with each button press for a total of two flashes.
    9. Wait 10 seconds and press the unlock button. The doors should unlock. The second transmitter is now programmed.
    ***If you have three keys proceed to step 10. Otherwise skip to step 16.***
    10. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
    11. Press the unlock button three times with a one second interval in between, the lights will flash with each button press for a total of three flashes.
    12. Wait 10 seconds and press the unlock button. The doors should unlock. The third transmitter is now programmed.
    ***If you have four keys proceed to step 13. Otherwise skip to step 16.***
    13. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
    14. Press the unlock button four times with a one second interval in between, the lights will flash with each button press for a total of four flashes.
    15. Wait 10 seconds and press the unlock button. The doors should unlock. The fourth transmitter is now programmed.
    16. Remove the key from the ignition.
    Make sure that to test the newly program remotes, the original key is removed from the ignition since this exits the programming process. Someone might be a bit frustrated trying to test it with it still in 'program' mode.
    I had some diffuculty accessing the programming mode. If it doesnt work then take the key out of the ignition and start over. Rinse lather repeat. It will go eventually.
    If you are still having problems after trying it more times than you can count, check the key is right one for year of car or that the key and battery are good. "
